1 hour ago, DavidADav said:
! I have not epilamed the escape wheel or pallet fork, and am kicking myself.
Epilame is not much a necessity when using synthetic oils, which are better in staying where you place them. It was introduce to improve location stability of natural oils, but was mainly used at production or top end service centers. It has never become universal practice, and even less after the said synthetic lubricants became available, around 1970.
2 hours ago, DavidADav said:
Oh, absolutely still learning.  It would be a shame to stop!
The interesting thing I found though, related to this thread (and not as much to my original question) was a problem I ran in to after oiling the pallet jewels.  With the watch oiled (and pallet fork arbor left alone), I had ~286 in dial up and dial down, and consistent amplitude in all other positions.  I had applied a small amount of 9415 to the pallet jewels before winding and letting it run.  I let it run for a while, all seemed good.  I then decided to mess with things, drained the power, and applied a little more 9415 to the escape wheel (around every third tooth).  Since then it has stuck at a steady 230 in dial up / dial down.
I let the watch run for a few hours and it stayed the same.  Yes, I could have let it run overnight, but I felt I could have cleaned it better and decided to drain the power, strip the movement, peg the pivots, clean everything and reassemble.  Post assembly, put a little bit of 9415 on the pallet jewels…~285 amplitude.  Drained, put a little more on the escape wheel teeth (a little less than before), and it’s stuck at 230 after running all night.
Yes, I’m new to the trade (about a year and a half in), but was surprised, as whenever I oiled using this method I would see a general increase in amplitude, not a 50 point drop! I have not epilamed the escape wheel or pallet fork, and am kicking myself - I’ll tear down and do that next, but thought it would not be necessary given this is a 1925 Waltham pocket watch…
That said, thank you for the link.  Given I’m experimenting at this point, I may give oiling the pivots a try just to see what happens.  If there’s one thing I’ve learned, there is no “one way” to oil a watch that everyone agrees on (well, I think we all agree not to squirt 3-in-1 in the poor thing).
Dave
Isn't 9415 for high frequency movements (21,600+)? Maybe 941 would be more suitable. 9415 is a grease and 941 an oil.
It is not for high-beats, it is especially recommended on these, where is shines due to thixotropic characteristics. It can be used on all watches when you have it, if not even 9010 is just fine. What David has found is simple the old truth about oiling -less is best. Especially on pallet jewels.
And there…I think we’ve found something we can all agree with…less is best. 😉
My plan at this point is:
  1. As I am now consistently running at 230 in DU/DD, I’m going to add a wee bit of 9010 to the pallet pivots, just to see what happens, and to satisfy my curiosity.
  2. I’ll then remove the pallet fork and escape wheel, clean both, and run with no lubrication, recording the results.
  3. I’ll then add some 9010 (instead of 9415), just to the pallet jewels, and record the results.
  4. Finally, I’ll strip and clean the movement, and oil based on the from my prior tests.  I’ve seen how the watch performs with 9415 just on the jewels (and not on the escape teeth), and will have tried the other scenarios, and will go with whatever delivers the best results.
  5. I’ll post my findings…
Thanks again.
Edited by DavidADav
Originally when It came out 941 was still recommended for low frequency watches. Then 9415 for high-frequency. But with time the manufacturers probably realizing how cheap watchmakers are changed to an either or and now typically it's just 9415 for everything.  Otherwise as stated above before 941 9010 was recommended
The only problem with 9415 is it is a grease with thixotropic properties. To understand the meaning of that I have a link. Which from the description brings up a problem for us? So in superthin quantities it slides really really nice. But if you get too much it's basically grabbing the edges of the escape wheel causing the problem you had noted loss of amplitude.
The watch companies are recognizing the problem which is why in the attached PDF you'll notice the extreme lengths they go to to get a superthin quantity. No you really don't have to go to these extreme lengths you just have to have less grease.
https://en.wikipedia.org/wiki/Thixotropy
Omega 8645_WI_40_rules for lubrication cousinsuk.pdf
Just a minor clarification here about less? If you look at the above Omega documentation they also cover how much oil to put an pivots. But to make the point more clear I'm attaching an image from Rolex something they used to give to their students.
If you look at older documentation or even when I was in school that conflicts with the image attached. The definition of too little would've been an acceptable amount. The ideal is almost unacceptable for too much. Then the unacceptable is still unacceptable. If you look at the Omega PDF attached above basically you have to Be able to see the top of the pivot otherwise you have too much.
Hi all,
Thank you very much for the tips and feedback.  As promised, I’m reporting back on my findings.
For (1), I added a very small amount of 9010 to the pallet pivots and saw amplitude increase from 230 to 250 almost immediately.  When running with no lubrication (2) and then adding 9010 to the pivots (3), I saw minimal change.  I moved on to 4, stripped and cleaned the movement (including cleaning the mainspring - it is a new, alloy mainspring that I had previously oiled, and am now running with no oil), then oiled as I noted before, this time oiling the pallet pivots and the pallet jewels with 9010.  After the movement sat overnight, I saw amplitude around 285 in dial-up in the morning.
I’m happy with the results, and at simply trying out a few different oiling methods. The watch is now timed, cased, and sitting in a makeshift stand on my work desk where I can enjoy it.
The last remaining item is to replace the crystal.  I polished it, to remove the major scuffs, but as you can see, it is yellowed with age and needs replacing.
Dave
ETA 2834 is the movement.  Beat rate is 28800.  I noticed some odd behavior on the timer after I oiled the ends of the pallet jewels.  I used light oil designed for the escapement.
Then I wondered...should I NOT oil the pallets for such a screamer?  Or maybe I need a super lightweight oil in this case (5W-30 vs. 20W-30, no?)
9415 is what you want and it was specifically designed for higher beat watches. This is also where epilame helps too. The quick motion tends to sling and spread thin oil like 9010; epilame along with the thixotropic* quality of 9415 helps it stay in place. You shouldn't see any odd behaviour from it. Very high beat watches that run at 36,000 bph are often treated with a very special lubrication at the factory, but when servicing they run fine on 9415. 9415 is also great for all escapement beats, even "slow" beat. I use it on cylinder movements. Fantastic lubricant.
*9415 is technically a grease; but under the shearing action at the junction of the escape tooth and pallet stone it drops dramatically in viscosity right at that point, that's a thixotropic lubricant. The greasiness helps keep in in place the thixotrop-iness keeps it from dragging down the motion.
Edited by nickelsilver
Next year I guess I will have to get religion on these oils.  I have been using just two: one for escapement and one for everything else (plus grease for keyless works).
epilame
Been pondering that expense as well.
thixotropic
New vocab.  I am familiar with non-Newtonian fluids which I guess a thixotropic fluid is.
I did a revisit of the movement after posting.  Removed the balance from the cock and inspected the hairspring closely.  All looked well except I may have seen a tiny piece of gunk at the tip of the regulator foot.  Could have been a reflection, but it is gone now.  This after several dunkings in one-dip.  Re assembled and it seems to be running very well.
Back to thixotropic...mainspring breaking grease would also be thixotropic, no?
  • Mark unpinned this topic
  • Mark pinned this topic
  • 1 year later...
On 3/28/2016 at 8:44 AM, clockboy said:
I learn,t this recently. The angle you use to load lubricant on to your oiler alters the amount & shape of oil on the oiler tip.
An upright 90 deg. entry gives it a tiny about of oil on the tip which is what you want for the pallet jewel. Also what helps is really good magnification.
Also the speed at which you remove the oiler from the oil gives a different loading. Fast = more and Slow = less.
  • 3 months later...
Trying to improve my process for pallet stone oiling.  I currently install the pallet fork, add a drop of oil to the exit stone and cycle the pallet fork 5 times and repeat.  The problem that I am having is that I am applying this with basic magnification with a loupe and some times I manage to scrape the oiler on the stone which ends up putting oil up the side of the stone.  I struggle to do this consistently.  The poor depth of field that I have with my loupe means I struggle to guess the depth of the stone when I am reaching through the movement with an oiler and waving it around.
I have seen that some people just oil the exit stone once before installation - I have avoided this technique because of warnings that you might spread the oil while trying to install the pallet fork (plus how well does this oil all of the escapement teeth?).  If I am spreading the oil in any case, perhaps I would be better to oil before installation as I can apply it directly to the face of the stone and get a consistent quantity.
I think that your issue is your magnification and practice, you can get better with practice and/or you could switch to a visor which would give you stereo vision and help in your depth perception and field of vision, or better still a stereo microscope if you budget and accountant will allow. I use an Optivisor when I use a visor as I have tried other cheaper versions with poor results. Also if you go down the road of a stereo microscope (which I recommend) you can pick them up fairly inexpensively on Ali Express, some will scream at me for saying this, but you get 90% of the quality(which is enough) for 10% of the price of brand name ones.
PS
I have been informed from a source I trust that AMScope do not make their own scopes, they simply buy them in and re-brand/box them
A microscope make this much easier.  My preference is to oil the teeth.this is a dedicated area to aim for rather than trying to shoot for the center of a stone. I found oiling the stone created more of wall either side of the groove the teeth made. Dont use an oiler but a fine hair bristle set into pegwood.
PS
Yes, I think a microscope might be my next big purchase (or a staking set, or a jeweling set).  I really need to improve my ability to inspect and undertake detailed tasks.
@Neverenoughwatches is saw you mention the use of odd brush bristles for this task and inserting oil into shock settings on another thread - What kind of brush bristle are you using?  Natural or synthetic?  Which part of the escape wheel teeth are you oiling?  The extreme tip of the club foot or up the sides as well?
I'd go for an optical microscope first over those tools.  I really wish I had bought one very early on instead of going with an optivisor and then cheap digital microscope.  So much nicer to work with when you can see what you are doing and able to inspect better.
 With a quick dip of your .6mm screw driver about 2mm deep into oil,  you get too much oil on the blade, some of which is to be drained down, if you  touch any clean surface with it, some oil will drain in a minute,  leaving you with little oil on flat surface of your screw driver.
 As you watch runs on tg , touch the running face of  each escape teeth with your oiled screw driver, let escape wheel turn  several rounds, then  observe the amplitude your getting on tg, you can keep on adding oil as long as the amplitude is on the increase, until amplitude stops gaining.
Be careful to oil just the running face  of each escape teeth, you wouldn't want oil on non functional sections of escape wheel.
Your letting the escape teeth distribute oil on sections it engages.
No excess oil  which can run/ travel  to where not needed. You can add a bit extra oil as reserve.
Let the watch run for up to two weeks in all positions or on wrist,   then epilame by same approach.
Your watch is showing you how much oil should be in its belly,  for best amplitude.  😅
Rgds
Oh please, don't tell de Clark I said this.
Edited by Nucejoe
Adding disclaimer
They are from synthetic brushes that i use for clean watch parts by hand, i think they are just nylon. I oil the impulse face of the escape teethl, i find it easier to do from the outside edge of the plate instead of feeding in from the top to oil the stones.
This was the method I was taught in school and I still do. You do have to make sure you do it three times to get the entire escape wheel.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
    • Could you fit a sapphire crystal? My 'daily wearer' Breitling Aerospace is 22 years old and there isn't a mark on the sapphire crystal.
    • Oh that's neat. I typically use a thin strap of rodico laid over the pallet fork to affix it to the upper plate but it can be hard to retrieve sometimes. And as I did more research, I may have just found your own earlier explanation: https://learntimeonline.com/forums/topic/potence-clip-for-full-plate-p-ws/
