Thank you VWatchie much appreciated sir I am sure I will need to refer to it.
I have seen you on WUS in the past along with Roland.
Best regards to you and have a great day, James.
On 10/30/2021 at 8:41 AM, jdrichard said:
So from my pictures, this device has a 2amp 250v breaker, and I am in Canada 120 volts and I assume that I will draw 1.1 Amps. Does this breaker even matter?
This unit Does Not have a 2 amp breaker, what you are looking at is the amp rating on the back of one of the switches.
This unit is un fused. the only means of disconnect is the rating of the breaker the watch machine is plugged into.
Edited by jimzzilla
You are correct.  Would still like to replace the rheostat
I got mine via DHL early this week and I am almost done fixing things to make it right.
I am going to post things I did so as to maybe help someone else who may buy one,
best regards to you jdrichard, james.
On 8/20/2022 at 4:27 PM, GuyMontag said:
If you come across anything that might explain how mine died mid-cleaning please do share.
Line voltage issue? rheostat took a dump?, first 2 off the top of my head, just guesses.
when you see how the rheostat is wired in you will be shocked!
I'm getting ready to post my unit soon.
Hey guy's finally got my cleaner finished and I would like to share with you what I did                                                            So you know I do have a prototyping back ground and am currently a mechanical contractor(H.V.A.C.) use this information at your own risk.
Picture below shows the wiring compartment. I removed the wires from the terminal block and soldered the ends of all the wires and re inserted back into the block. these blocks are not too bad so long as you don't over crank the screws.
I had to re do the rheostat, this is what I saw when I un wrapped the tape, yes tape!
Looks to me like an India style western union style splice, horrid! 🤣
I soldered the wires properly and sealed with some glue shrink.
This whole machine is put together with slotted screws so on the fasteners I need greater access to I used
Allen head screws and had to re tap the threads.
The wiring on this unit is OK meaning it is good enough, the quality of the wire is nominal
This machine draws very little amps so wiring size wise it is OK but on the other hand the assembly
process is VERY poor and that is why like everyone else said THOROUGHLY CHECK ALL THE WIRING OUT
BEFORE USING THIS MACHINE.
This unit is not grounded and does not have a fuse or breaker so I got rid of the un grounded cord and made up a 2 wire with ground power cord and installed a fuse holder in the existing hole on the base of the machine.
The 40 year old MIL-SPEC tank fuse holder dropped right in.
I used a 1.25 amp fast blo fuse my amprobe showed .3 Amps RLA no heater and 1.4 Amps RLA with the heater and motor on. I ran the heater and motor on a full timing cycle, I think 12 minutes straight to see if I could get the 1.25 Amp fuse to give up the ghost but it was fine. Your machine may have slightly differing characteristics  (sorry for the poor pics)
I got a picture of the motor and heater assembly just for s**ts and giggles
All in all I just went through the weak points of this cleaning machine and tweaked what I thought needed it.
I think It runs well for what it is ......  an entry level cleaning machine.
I cannot compare it to the Elma as I do not have one to compare it too but for my use as an amatur
I think it will serve the purpose.
Here are some before and after pics, best regards, James.
  • Mark unpinned this topic
  • Mark pinned, unpinned and featured this topic
The instructions say to "Upper bush of the motor should be oiled twice a year with good quality mobileoil" Anyone know how to do this?
Also, my rheostat sucks when it's in the air. It's basically on or off. Is there any solution to this or replacement part that anyone recommends?
Elma machines behave the same. These rheostats are no real speed control, they need the water resistance to work kind of.
Soldering the end is less secure than the bare wires and is avoided since many decades.
The solder will give in by and by, the wire can get loose, hot and even catch fire!
Today end sleeves are used.
Frank
Frank
Hello Frank I hope you are doing well sir. I don't think it matters as this machine draws so little amps.
by soldering the wires they become one and cannot ark in the lug and if you torque the screws properly they are secured,
I could see if this was a 10KW Heater drawing 55 amps but this is a 1.4 amp circuit. I am confidant my wiring is secure.
The only time I have had a problem with a soldered connection Is vibration.
If you have a soldered connection and the wire it is not properly secured it usually breaks at or near the terminal end.
JMO.
JMO,
you are right that it is a lesser issue with lower current.
But why not use the right procedure in every case and get accustomed to?
Even if you torque the screws properly, the solder will try to creep and avoid the pressure.
Regards, Frank
Is that a bad thing? When it is in the air, it needs to spin a full speed to centrifuge out all the cleaning solution. 😉
Maybe cause I had heavier pocket watch parts in it, but when it goes really fast it seemed out of balance and was vibrating a lot.
On 9/16/2022 at 6:14 AM, praezis said:
JMO,
Regards, Frank
I agree with you Frank but personally I have not ever had issues with soldered connections being tightened down in lugs.
Here in the USA a lot of the manufactures tin the end of the wires such as ceiling fans and many light fixtures.
I mean if I wanted to go "Full Monty" I could have replaced everything but IMO it doesn't need it.
I am currently in the process of machining another basket shaft as the one that came with it is terrible,
after I finish the shaft it will be a solid machine.
Best regards to you Frank, James.
The motor ramping up is to some extent the characteristics of the universal type motor used in this machine.
Everyone complains about the  rheostat as well as it doe's not have enough sensitivity but it does
work better in the solution as there is more drag on the motor. I was going to replace mine but
so far seems an impossible task to find a suitable replacement unless you are an electronics guru.
It would be nice to find one muddtt,
best regards sir, James.
P.S. It could be the basket shaft is out of round like mine and causing vibration,
how true does everything turn? check that out.
You may have to have someone make you a shaft as well.
Wow, this this conversation takes me back to my years as a "wire monkey" working for a machine tool builder.
The enemy of any connection is vibration, and every type of terminal block is susceptible to it to one extent or the other. If a machine tool started exhibiting intermittent, flaky kinds of failures, one of the first course of action would be to go through and check terminal block connections, and reseat any components that used edge connectors.
Terminal blocks are useful if you are looking for quick assembly, or if you expect to take things apart or change them.
The most reliable type of connection is permanent. Strip the wires, twist them together, solder them, then insulate. For small gauge wire, heat shrinkable tubing for insulation is fine. I personally would not use wire nuts to provide insulation, I don't consider them reliable in a machine environment.
We would really get serious with high voltage motor wiring in a tough, vibrating, machine tool environment. This was often heavy gauge wiring. We would strip and solder the ends together (parallel, couldn't twist), clamp the ends with a brass clamp to provide additional mechanical strength, wrap the end in soft rubber tape that fused together to provide a sealed insulated cover for the connection, and then wrap that in a high quality electrical tape.
These connections could last decades in very extreme, environments, with lots of vibration and moisture.
Hmm, almost like a watch cleaning machine 🙂
Cheers!
Hi dadistic I hope you do well sir.
I am still a wire monkey as I am currently a H.V.A.C. contractor and I do not like wire nuts either        but they are a quick method of joining 2 wires together. I have seen them burn through if you do not twist the wires together tight enough on restive heating circuits and the wires arc internally inside the wire nut and melt the wire nut.     Like I was telling Frank this watch cleaner does not have the amp draw or vibration that I feel warrants the extra effort to do all the extra tweaks to bring it up to a MIL SPEC  standard IMO. I have only had it for more than a few weeks now and so far it has performed flawlessly except for the basket shaft that I am going to have re done.
Down the road If I have problems I may consider addressing It at that point. I also agree that soldering is the way to go but for me I don't want to put the extra effort into soldering all the wires., like I said if I have problems down the road then I may have to do that.
Best regards, James.
Edited by jimzzilla
That's the way I handle my own stuff myself, if it doesn't need to be addressed at the moment I usually leave it,  most of the time I have other things I'd rather do.  Life is short 🙂
Perhaps someone who reads this is having strange problems with their machine, or wants to rebuild it, and my two cents might help.
Cheers!
I agree sir and slowly this thread is gaining more and more information on the Pearl cleaning machine
so it is bound to help others, best regards and have a good evening.
This is what it looks like when I'm spinning parts in the air. I have the parts reasonably spread out so the weight is distributed evenly. What do you guys think?
Mine would shimmy when I was in the spin cycle (in the jar, out of solution) causing the basket to creep up out of the jar, flinging solution everywhere. Then it died. Total waste of money for me as the guy selling it refuses to answer any of my emails.
Was your machine able to control the speed when it was in the solution?
Also, is the voltage correct for your country?
Yea. If the seller doesn't help me, hopefully Esty will. If not them I'll do a credit card charge back. Hopefully it never has to come to that.
In the solution the speed control works great. And yes the voltage is right for my country.
What’s the quality of the baskets like? I’ve been uhm’ing and aah’ing getting one. I know full well I’ll end up rewiring it and making it safe, but the big thing is the baskets for me. I’ve read that the coating on them flakes off and end up in the watch parts - not sure if that was an isolated case?
Looking at the vid I would guess the basket is at fault or it’s not being secured tight. When fitting the basket it should be a a tight fit. I have owned/ used one of these machines for the last three years with no issues whatsoever..    As always it’s a case of the elimination process. Such as spin without a basket to see it all is true. Try a different basket etc etc. The pic shows the springs that add tension by pressing on the top of the basket .
Edited by clockboy
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
