Hamilton 689A autowind problem
Hi all,
I just serviced a newly acquired Hamilton 689A movement (aka ETA 2451). The movement without the auto mechanism attached runs fine, good amplitude, rate, beat error. When I attach the autowind mechanism (which has been properly cleaned and oiled), the rotor doesn't move freely. It can be moved manually, but its weight won't move it. There's no visible sign of it touching the movement plate anywhere. The rotor moves fine with it's off the watch. I found that when I first attach the autowind movement without screwing it in, the rotor will move as I rotate the movement. If I screw it on tight, the rotor won't move freely. If I back those screws up about a 1/4 turn, the rotor moves and winds the watch. But I don't want to use the watch with slightly loose screws because I'm pretty confident they will loosen completely.
Any ideas what's up? I've attached movement photos, but there's not much else to see, at least nothing I've found, that would explain the problem.
Thanks!
We can't possibly remember all details of the auto module geometry, so if you will please show a picture with auto-device removed. to show;
- The ratchet wheel
- The jewel to ratchet wheel reduction wheel.
The lower jewel to reduction wheel ( if there is one) and has moved can bind the reduction wheel.
Wrong screw on ratchet wheel can also cause a bind.
Check posting pins and if module plate is bent ....
See if shimming between the module plate and the bridge it mounts on releases the auto- device to wind.
Keep us posted please.
Regs
- The ratchet wheel
Regs
Correction: Check modules  locating posts.
Thanks for the replies.
I think there is some distortion of the plate. I didn't notice the distortion when I first got the watch and probably attributed poor movement of the rotor to its needing a cleaning. But when I position the auto mechanism on the plate, screw in one side, the opposite side does lift slightly. That's the first time I saw something like that on an ETA movement. So it could be distortion of the watch plate, or of the auto mechanism plate. I may be able to temporarily borrow an auto mechanism from another 689A, attach it to the main watch plate, and see if the rotor works properly. If it does work then I'll know it was the plate from the original auto mechanism that was distorted. If it doesn't, then it could be the plate from the watch, or something else fouling things up. I'll try that for a start.
DanB, you need to wind the crown a bit as you lower the autowind, this will allow the winding gear to engage the ratchet wheel.
Also does the weight spin freely when the autowind mechanism is off? On some models the autowind weight spins on a plain bush, others have a jewel. This is needs to be really clean.
Anilv
Hi Anilv,
Thanks for the reply. Yes, watch was wound slightly to engage the auto mechanism with the ratchet wheel, and the rotor does spin freely when it's off the movement. When the auto wind is on the watch and its attaching screws are slightly tightened, the rotor does spin freely and winds the watch. It's only when the screws are tightened all the way home that the rotor starts to bind. Back the screws up a quarter turn and it spins freely again. It made sense to check if the rotor was getting hung up on a screw head, but not that I could tell. I'll keep troubleshooting...
Make sure you have some end shake on ratchet wheel's reduction wheel.
Shimming the automatic bridge( winder module) is a diagnostic approach which can as well be a quick fix.
If you can't find a thin enough shim, your next easy fix is to gouge the automatic bridge.
Hi all,
Problem is now solved, and it was pretty simple. I had the reduction wheel installed upside down. Once installed properly the autowind mechanism went back on without a hitch. I realized something was wrong after the watch was back together and it ran out of juice despite the rotor working properly. Lesson learned.
Thanks again for all the help.
2 minutes ago, jerryvs said:
if you wind manualy the ossilating weight moves?
Fault in winder module( the auto device).
How did you clean& lube the reversers?
Reversers throw oil outward( due to high speed)  and dry up before long, so should be treated with epilame as well.
i have the same problem with 2824/2 revercing wheel, the Auxiliary Reversing Wheel in particular.
 i use Lubeta v105 personaly
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
