For me, it has to be a classical symphony, or a piano concerto.
About three years ago, I discovered a classical radio programme that
is available 24/7 online from Washington, USA.
I 'bluetooth' it into my 5:1 surround sound system.
Since then, I have never looked back, or bothered with the outdated and drab; BBC radio 3.
In fact, I have absolutely nothing to do with anything via the BBC.
I gave up the TV several years ago.
YouTube is far more interesting and you do not need a licence to view.
12 hours ago, dadistic said:
Which one did you find? There seems to be more than one. Is it King?
Thanks!
Hiya, dadistic!
The one I found is, 'Classical WETA.'  (90.9 FM. Washington based)
Brilliant programme.
Due to the 5 hour time zone difference between here, in the UK and the USA, there are some parts
of WETA that I cannot listen to.
(Gotta get me zzzzzzzzzz's!)
They have a sister channel called, VivaLaVoce.
That one is dedicated to opera, but I prefer the classical music on Classical WETA.
Regards.
Len.
Speaking of streaming (something that can't easily or reliably be done on my internet connection), I used to do a fair bit of it. These days (owing in part to the aforementioned lack of communications infrastructure), my music is 100% vinyl. 6-8 hours a day playing in the background, just rolling through my entire collection. I'm also a software engineer, and spend too much time in front of a computer screen for my eyes, and glasses are a fact of life. I've found that the ~20 minute/side is the perfect interval to get up from whatever eye intensive thing I'm doing to give myself a break. I know the topic is re: music, but the form factor plays a part as well. Also, hi-fi audio has a lot of mental overlap with horology, and I've got a tube pre-amp project on the back burner... Well, it's been a bit more in the front over the last few days, but it's a relatively low priority due to the same desk hog project that's keeping the watches in the drawer.
  • 4 months later...
I just thought it worth waking up this thread with today's suggestions.
Klaus Schulze - My Ty She
.. and perhaps if you enjoy Indian classical music a little bit of mellow bamboo flute might be just the thing to keep you "in the zone" while trying to massage those hairsprings.
Edited by AndyHull
On 1/22/2022 at 9:46 AM, Len33 said:
Victor Sylvester orchestra and the unmistakable violin sound of Oscar Grasso.
Very nice but I think something is wrong.  The left channel is totally dead.  😁
I like listening to Oldtime.radio.  They play old time radio shows from before TV and you can download them as mp3.
12 hours ago, nickelsilver said:
Came up in the Spotify liked songs playlist today and was a hit while working on an abused Omega 321 chrono!
I like it !
That's good working music - hard to classify, a bit of everything. (How do you insert a YouTube clip ?)
I love a bit of 70s prog -
https://youtu.be/hGXW5d5f-LM
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
