Need help for Omega Seamaster caliber 562
Elton
Thanks Clockboy. It is automatic movement - watch has missing parts therefore looking for quartz replacement as an option.
OmEGA details:
Dm= 27.9mm, Do= 28.4mm
H= 5.0mm
F= 1.75mm
T= 2.15mm
24 jewels
f = 19800 A/h
power reserve 50h
Balance staff U2769
Stem W2790
Hands
1.50 x 0.80 x 0.18mm
OmEGA details:
H= 5.0mm
F= 1.75mm
T= 2.15mm
24 jewels
f = 19800 A/h
power reserve 50h
Balance staff U2769
Stem W2790
Hands
You will run into many issues, including fitting your dial, a need for some sort of mounting / fitting ring (usually plastic), adjusting your winding stem, etc, etc.
However, you can start searching here simply using your existing movement diameter and height:
https://www.cousinsuk.com/category/filter/watch-movement-search-match-by-millimeter-size
it does not have to be Quartz, you may find some mechanical movements suitable for your case.
Is it so bad that repairing your Omega movement is not an option?
10 hours ago, Elton said:
I'm just wondering if I can find a quartz movement as suitable replacement. Quartz Movement number if available would be appreciated. Dial O/D is 27,5 mm. Thanks in advance.
Are you sure it can't be repaired ? There seems to be most parts available for this movement - check ebay and Cousins.
Yes you could probably put a quartz watch in  but  a lot of work is going to be required to find a suitable movement that lines up with the stem  and still has the hands in the right place for the dial.  Specifically the thickness of the movement has to agree with the thickness of  the original movement. Then more likely the hands will have to be replaced because usually  the quartz movement has different hand sizes in the regional watch.
Apart from a few missing parts, the main plate center jewel is damaged. The next option could be a spare Omega movement from eBay but it may cost between $ 180 - $ 200 AUD.
Are you aware that the center jewel could be replaced? The missing components depending upon what they are can be an issue. Sometimes it is cheaper to get a replacement movement. But did you know this is a discussion group of people who repair things maybe we can help you repair it?
Don't just give up the idea of repairing the 562. It is a really nice movement and will be worth the effort. Once it's back to life you can enjoy it for many years.
But just as watchweasol said first list the parts you need to buy and check how much it would cost.
Good advice but challenging. I ruined the jewel hole as I tried to improvise and as a result I rimmed the hole too large. I'll persevere & still look for other option.  Apart from that more missing parts like cannon pinon ,winding stem ,& cog wheels all of those can be obtained from ebay (Omega spares). Biggest hurdle is the main plate which I ruined the center jewel hole as mentioned earlier.
As long as the hole for the jewel is still centered it shouldn’t be a problem to fit a new jewel with a larger outer diameter. But I would recommend you to let a professional watchmaker do it, these can easily crack and they need to be perfectly sized. But it doesn’t necessarily mean that the main plate is ruined
6 hours ago, clockboy said:
Agree with “handwound”  this is a job only to be attempted with the correct tools.
I would say with skills and experience more than anything else. You can see great work done by a master with mediocre tools, but never the other way around.
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
