omega 283
gary17
Usually to get the correct answer it would help to post a photograph. Otherwise you get the correct answer above but is it the correct answer for your watch? I was looking at the parts list and it looks like the spring that does not go on top.
It's the amusing problem with watch repair lots and lots of variations. All these companies had clever ideas for doing things sometimes I think to get around patents other times perhaps to have their own patents or just because They like torturing the watchmaker.
The problem with your watch is it's cold and trying to find a really old tech sheet is a problem. I think with this one it goes underneath because If its on top I don't know if there's enough clearance between the pivot and the little bridge that holds it in place.
The springs goes underneath the pinion and the bridge on top, there is to be a .02mm clearance between the pionion and jewel thats in the upper bridge. Oil top and bottom interfaces of the pinion with the spring and the jewel. The spring is to hold the pinion high enough to engage leaves with the other wheel.
Both the spring and minute arbour look like they have had it, I am not sure if oiling would be enough, I would polish both.
Good luck.
Good luck.
Some say the clearance is not neccessary and the pinion should barely rub on both side, but in this case no clearance might eat amplitude or even stop the movement couple of months down the line.
This is how your spring should look.
Your looks a bit bent out of shape, but as long as it pushes up in the correct place on the underside of the sweep second pinion, all will be good.
As has already been said,  the brake spring (which is made from beryllium copper) pushes from underneath the pinion and needs a small dot of grease on the spring where it makes contact with the underneath of the pinion leaves.
It tends to be obvious which way it pushes the sweep second pinion, either from the top of bottom, when you see the spring in place without the sweep second pinion. The spring will show it is pushing down or pushing up, unless it has been badly mis-shappened like yours.
I could be wrong, but I think it may have been the intention that the fancier beryllium springs were left dry. The material has a unique ability to work against other metals without wear. I’ve not seen it mentioned on Omega tech sheets in terms of lubrication. I used to always oil them but then also needed to bend them to increase the friction, so now I just leave them as-is. Would be interested to know if anyone has an original tech sheet which mentions them.
2 hours ago, Tudor said:
Can I have a copy of the Omega oiling chart(s) you have please?
The problem is this watch is too old we need something newer with equivalent spring to see what the recommendation is. But if you'd like an Omega oiling guide you can find it In the list at the link below.The reason there is a list is it covers all of Omega's working instructions that cousins has which is not all of them unfortunately. But you might find something else of interest in the list also. You're looking for number 40 by the way.
Then the problem with omega having of these working instructions or the equivalent for some time that would explain why we find lubrication instructions sometimes lacking in the regular technical guide because they want you to look at the lubrication guide instead.
https://www.cousinsuk.com/document/search?SearchString=Working
That, is an excellent resource, thank you!
I have downloaded all the Working Instructions there, so I have them for future reference, even though I don't foresee working on a ceramic case Speedmaster any time soon...
I have harvested documents from Cousin's in the past, but hadn't come across these. Much appreciated.
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
