I’m new and love watches + Help please ?
SiSays
Hello my wonderful watch people.
Like many of you I am a real watch lover, this began about 3 years ago and I have purchased many, many watches in this time...
However, I have encountered a problem ☹️
I have attempted to change a capacitor in my Seiko Kinetic watch, managed to get everything out thanks to the ‘watch repair channel’ but having got the new capacitor installed I have lost the tiny screws required to put the plate above the capacitor back and then the rotor.
Any help would be greatly appreciated as I am lost for ideas and have been to multiple jewellers etc with no luck..
Thank you
Get a small neodinium magnet and wrap it in white painters tape. The tape only serves to make dark objects stand out against the light background, so it is optional.
Remove any other watches from the area you were working in so you don't affect them with the magnet,  and carefully and methodically  sweep the bench, carpet, your trousers, socks, jumper floor, and everything within a few feet of your work area. Hopefully the tiny screw will stick to the magnet and you will see it sitting smugly on the white tape.
I have lost count of the number of times I've had to endure this little ritual, looking for tiny springs, screws, watch hands, winders and all the other little parts that like to mysteriously vanish from the end of my tweezers. I recently found a spring from a Sekonda that I lost a few weeks back, while looking for a screw that I had just dropped. I also found the screw ?
Brass and stainless steel parts are more tricky as they wont stick to the magnet. For those, I attack the carpet with a piece of duck tape, in the hope that I'll pick up more parts than carpet fluff.
Edited by AndyHull
Thank you so much for your responses everyone ? I need 2 small screws to hold the capacitor bracket on and a slightly bigger one for the rotor.
I’m at work at the minute but can uploads pictures this afternoon if that would help.
I am in the UK, namely London and May need to get someone to fit it for me if I can’t. Am happy to pay..
4 hours ago, philipk5 said:
Same two capacitor small screws as in pc21 etc movement. Are you in the UK ?
7 hours ago, Watchtime said:
If you can send me the caliber I am happy to check if I have it in my parts drawer
Please find a picture attached... as I say, any help would be greatly appreciated...
Do you have any broken/non working scrap ordinary quartz Hattori movements such as the PC21 ? If so use the the small screws that hold the coil etc in place. As far as the rotor holding screw as suggested invest in a magnet and scour thoroughly the general area it went missing. Missing small parts do seem to reappear given time to drop out of orbit!
Good luck.
The screw screws into the centre of the bearing so the only danger of overtightening is to break the screw!
It should be tight enough to stay put but not so tight that it breaks (obvious but completely useless advice!!!)
Glad to have helped.
    • Yep, i pulled that up as well when i was looking,  there is definitely parts out there if you are prepared to go out and find them.  I watched that video years ago, I'm not so sure about probing the coil like that. If you are going to touch the coil use the side of the probe or at least shape a nice round end to it.
    • Hi and welcome to the forum.   As you are already familiar with watches the attachment you may find useful Witschi Training Course.pdf
    • I saw this listing from Australia this morning on Ebay, it might be your only option, good luck.... https://www.ebay.com/itm/145735044565?itmmeta=01HWCRFPEYDDTCXYCRX7ESQH3K&hash=item21ee7c4dd5:g:f2oAAOSwaMhmI5tq&itmprp=enc%3AAQAJAAAA4PzZAWzJj0HOwVM7Xl6qUqGIYly3BvZhzNybkxWf8GJYkKwVh0SpeZ0XYBmoZyjaboPOlJYzdY9svwhQXfR7V%2BiMApTEYFLvJcs8FxTzy1VFCBLR8ADc7V89%2B%2FYvQKdks2KDNNEqAFZN0Hni9zQG078wKL34x0eRK%2Fu843fYdH%2FVIAiOZ5%2BbOmySNdu%2Bv4cSemywC%2FWfaiI%2Fj5D3YWk2PaySdPfu7lUaMadcyhmHZM6l6NllJd1eK%2BdblkJD98pTzVuxRDne5AQaCYawls%2FaoQK9B7epV%2B87TIbD9Ulr4qdC|tkp%3ABk9SR-rnvpjjYw
    • Hi. In the picture not only does it depict that the wheel is bent but also the plate or is that due to th angle of the picture.  Already received very good advise so I will butt out.
    • welcome, sounds like you are on your way so far, you also might be able to help with gold/plated case repair for some .....
