I was thinking about using Fixodrop but  have a hard time figuring out what parts to use it on. The fewer the better considering the abhorrent price for it. What I got so far.
* Pallet jewels
* Escape wheel
* Reversing wheel on automatic
* Balance End stones
What is your opinion on this ? Should the end stones be treated, and if so, does that include the chaton ?
Link to post
It is used to stop spreading of a lubricant all over the surface. Where ever you oil pivots that is the time to use it. I myself never used such stuff, not sure if it was around in my days, besides I had a very steady hand.
Link to post
https://www.cousinsuk.com/category/moebius-fixodrop-fk    This link will give you ther page on Cousins site regarding fixodrop/Epilame  not only is it expensive, there are also hazzards in using it as explained in the following link  http://watchmakingblog.com/2011/07/29/one-hazard-of-epilame/.  I would suggest reading both and makining an informed descision         cheers
  • Thanks 3
Link to post
Yes it was, 1957 Omega literature explains it, in the 60s Greiner made a machine to apply it from bags of stearic acide, after ultrasonic cleaning.
I've neither used it so far, I think that today's quality of lubricatints helps doing without it, at the same time I don't have enough experience to recommend one way or the other.
Link to post
15 minutes ago, praezis said:
Don't forget to run the movement dry for some minutes, before oiling.
Frank
You should never run a movement dry. It needs lube no matter for how long. More then likely you will need to add oil as you re assemble the movement as the more you add parts the more difficult to oil certain parts become.
Link to post
In csse of runing movements, I take dial and disk plates off, wind full and drop the whole movement in avgas( absolutely friendly to shelac) , if it ran whilst submerged, I lets it run overnight to clean itself, then disassemble it for clean& service.
 My late repairman frowned on this practice of mine but never explained the reason.
This is a chance to put my question to vote, your thoughts please.
Link to post
By avgas you mean kerosene I guess? Why not, I don't think it will hurt anything, but getting all of that cleaned off would eat a lot of solvent or cleaning solution.
Link to post
Link to post
Aviation gas = avgas ,  I am not sure if this grade of avgas runs piston airplane or turbine engines( diferent I hear), but has no effect on shelac and no visible effect on base metals either.
Some calibers wont run while submerged.
Thanks for your response.
Link to post
15 minutes ago, oldhippy said:
It’s one way of causing extra wear on a movement, pivots could shear off, all sorts of damage could happen.
Oh I mean submerged and running with oscilator, so runs at low speed, if thats your concern, amplitude also drops.
Link to post
I’ve done something similar to what Nucejoe describes when doing a “pre clean” on an utterly filthy movement with L&R cleaning solution. Personally, I don’t see any great risk of harm. The aviation fuel probably provides a reasonable amount of lubrication for the short amount of time that it is running.
Link to post
Avgas has lead in it. Is it enough? No idea. It’s 100 (min) octane gasoline.  Turbines (jets) run on Jet-A which is essentially kerosene.
I had also considered such action at times (with Ronsinol) but never did. Cleaning is always better when you have access to both sides of plates.
Edited by Tudor
Link to post
On 8/29/2020 at 3:44 PM, nickelsilver said:
Run the movement with the pallet jewels dry for some minutes, this allows the escape teeth to scrape off the epilame from them and that non-epilamed "track" holds the oil.
Thanks, nickelsilver!
I was referring to the epilame treated parts only, acording the topic.
Frank
Link to post
One of the problems with watch repair is the age of the technical information. A problem with the age of the material is it's possible that things have changed like even fixodrop? Like for instance at the link below there is variations lots of them? Plus they've changed the solvent to something more environmentally supposedly friendly. Changing the solvent has had other interesting changes.
For instance 7061 This one's interesting wash resistant if you download the technical sheet it tells how to apply it. Then since I really enjoyed the answer "NO" up above I'm going to quote something "Fixodrop-treated anchor pallets should be lubricated only after running dry for 1 to 2 minutes" Unlike the answer "NO" up above it's okay because it's only the pallet stones. You need to remove the surface treatment so the oil will stick otherwise you're going to have issues.
Then they explain the drying procedure. This is interesting because the previous solvent they were using would evaporate so fast that if you weren't very very careful the cooling effect would cause moisture to condense out of the air eaving a microscopic coloring of moisture on your nice clean steel parts which leads to rust. This is why shops using this a lot of times I have a hot hairdryer radius and is a part came out that immediately put hot air on to hopefully avoid this. Now it's supposed to be better and not have that happen.
Only the end stone should be treated not the setting.
http://www.moebius-lubricants.ch/en/products/epilames
Link to post
  • 8 months later...
To support what others have written, I was just warned by a professional watchmaker to not treat the chatons as they could rust.
This same watchmaker does not treat the end stones because he feels it's unnecessary but he definitely treats the pallet fork.
Link to post
  • Similar Content
    • By EatPeach
      I've been using  Moebius 9415 to oil the pallet stone. I usually oils the exit pallet impulse face with the amount like you drop a little bubble on it.
      I really don't know how much amount I should applied and is there any sign to tell whether I'm overoil or underoil.
      I have one strange case though, the movement right after assembly has 260~270 amplitude but drop to 230 after 10 minus or so. Is this relevent to the pallet stone oiling?
    • By Graziano
      Good evening all , just wondering do any of you guys or gals like to use capillary fountain oilers . I have been using them combined with dip oilers for a while and I must say I enjoy using the capillary oilers some times over the dip oilers . Am I old fashioned or what ?
    • By Bethan36
      Hi Fellow People,
      Im reaching out as I’m currently learning all I can about watchmaking, and am working through the BHI distance learning technicians course, with my exam booked for May.
      I will need to service a quartz watch as part of my practical exam, and am learning about watch lubrication.
      A few months ago I found a great article that covered the technique for dipping and collecting the right amount of oil on the oiler, such as the speed and angle of the dip, however, I now can’t find it anywhere, no matter how much I search the internet
      Does anyone have or can point me in the right direction of instructions specifically on oil collection on the oiler?  As you will know there is lots on the actual oiling process but not the oil collection process.
      Any help would be greatly appreciated.
      Thanks
      Bethan
    • By VWatchie
      These jewels are from my very first ETA movement that I'm servicing (cal. 1080), and none of the movements I've been working on so far (Vostoks, Poljots, and a Unitas 6498) has had jewels like these. My question is simply how to oil them? They do look a lot like cap jewels and maybe that's what they are called? If I were to guess I would say that they should be oiled the same way that spring cap jewels are oiled, but I'd really like to know for sure. And, while I'm at it, what's the purpose of these non-springed "cap jewels"? I've also seen them in pictures of some really old movements having a balance without a shock spring.
      The movement comes from my grandfather's (born 1910) Ernest Borel Incastar which we believe he bought sometime in the early 1960-ties. It's a family heirloom, and I've been waiting to service it until having worked up some confidence. I had no idea it harboured an ETA movement so that was a pleasant and rather exciting surprise. As far as I know, it has never been serviced.
      As can be seen in the above picture it has a really interesting regulator mechanism, and I actually found this ad for it on eBay. Setting the rate I would assume is just a matter of rotating that five-pointed "star", but I wonder if that entire arm can be slid to regulate the beat error?
    • By matabog
      Hello!
      Do you oil the shouldered “safety” screws that hold in place the coupling clutch 8080, the sliding gear 8100 or the hammer 8219? If so, do you also put a very tiny drop of hp 1300 under them?
      you can find the entire doc here: http://watchguy.co.uk/wp-content/uploads/2012/12/Le-Landeron-48.pdf
      Thank you!
      Bogdan
