As the title States, I have found another early mechanical device in order to occupy my free time between watches or while waiting for replacement parts from overseas. I picked up this 1915 Underwood Model 5 Typewriter. I plan to do a full restoration on it. Mechanically it's in shockingly sound condition. A bit rusty, but nothing a good soak in some Evaporust won't take care of. The only part missing is the drawband, the part that provides tension to the carriage and allows it to advance with each keystroke and return at the end of each sentence. I've already got a plan to address that. The platen (roller) is stiff, but there is a company that offers a restoration service, if the pricing is reasonable. Somewhere over the last 105 years, the machine was repainted and all the original decals were painted over. Thankfully there is a seller on Etsy who has recreated all the decals for nearly every vintage and antique typewriter. This weekend I will be giving it a 24 hour soak in evaporust and then rinsing it and making sure it's dried and oiled to prevent any further rusting. I will then begin masking it off to sand, prime and paint a high gloss black lacquer like when it was new. Then decals and order a new black and red ribbon. I'm excited for it. The best part, the typewriter only cost me $30. Will share updates
One interesting sidenote, someone has compiled a database for typewriters nearly identical to the pocket watch database. An invaluable resource!
Edited by FLwatchguy73
Good luck with it!  I love those things, but am just running out of room.  I gave away a perfectly gorgeous Woodstock to a local railroad museum when I retired  and left the city.  It was since then that I learned of the platen restoration guy.
I used some of the very last manual machines made in my work.  Olympia as I recall.   Literally made by the company from spare parts stock.  Nothing sounds like those things at the hands of a skilled typer. DING!
....But - I really am out of room!
Very Interesting!  Good luck!  I couldn't help but notice how closely the wheel in your 5th picture resembles the index wheel and fingers of a Bulova Accutron (at least I think it does)
That is the escapement that controls the ribbon feed. Each time your strike a key or hit the spacebar it advances the ribbon a bit so you don't hammer all the ink out of just one spot.
Ingenious design, you can run the ribbon forward, then by pressing the whole gear and it's associated shaft to the right, a different set of transmission gears engages and now you can rewind the ribbon. Beautiful engineering. Discovered this by accident as I had no idea how any of this worked previously.
After a good soak in Evaporust. It may be difficult to tell, but the entirety of the rust is now gone. I can tell you if y you use it, it does loose strength over successive uses. My son soaked his Remington typewriter first, and it came out better, mine required a bit more labor. At any rate, the entire typewriter is ready for sanding and priming.
Below you can see after sanding and masking it's ready to be primed. I choose a sandable filler primer to hopefully even out some low spots, we'll see. The primer went on OK, (no pictures yet) but it hasn't cured all the way. I tried sanding a small piece and it just loaded up the sandpaper rather than turning to dust. One last observation, the original paint is an iron oxide base, black paint or lacquer. I know this because the dust from sanding it looked just like rust, I googled it and sure enough, it was the standard finish of the day.
Wonderful. Watches, clocks, typewriters, calculators, pin balls, jukeboxes, sewing machines, I love them all and I love to watch people restoring and taking care of these. Fortunately I managed to control myself until now, but what will happen when I'll have lotsa of new more space?
BTW that lawn looks to be in stellar shape!
Early typewriters like that are just magic, good luck with the restoration.
My main other 'time stealer' is my 1970s Chicago Coin Hollywood Pinball machine.
When I bought it most people would of considered it just a parts machine, now many many many hours later it is now playable though it still has some twitches that need to be ironed out. I was lucky I placed an order for NOS parts out of Canada for it in March just before all international postage went crazy. It only arrived a week late and I've since discovered I could do with replacing a couple of more coils but they will need to wait until postage between USA or Canada and Australia returns to some level of sanity
In these times of wear and tear where we're brought up to be good consumers not expecting anything to last, we're flabbergasted to see something that was designed and built to last indefinitely. If we could go back to those days environmental problems would quickly become something of the past. Beautiful machine!
Edited by VWatchie
Thank you. Here is today's update. Color coat of black acrylic lacquer has dried nicely. What a fantastic paint btw! Looks great. I unmasked everything and began the task of lubricating all the moving components. Letters, numbers, spacebar, tab, shift, all of it. I partially assembled the carriage and confirmed function. All is great!  I still have to source a drawband material, but I have a few ideas. Still a couple touch ups, but not overly concerned about them.
In my youth as a typewriter Tecnician(Office machine Mechanic) we stripped these Underwood 5s down and had them stove enameled and re chromed , They were a simple mechanism and would work for years Nice little machines.. These machines along with Imperial 50s 55s, 60s were the staple of the Yorkshire Post reporters room. Many of the roving reporters used Imperial Good companion portables, another solid machine will give you years of pleasure and use
1 hour ago, HectorLooi said:
I wonder, in a hundred years from now, what antiques will our grandchildren be restoring? Apple iphones? :D
I'd guess not as they are designed to be consumed... wear and tear...
HI   A Drawband can be made up of a flat bootlace  had to do it when we had not any in stock they worked well enough but we always changed them for the real thing later but they got you out of a hole.
  • 4 weeks later...
Old original B&W Gameboys, Tomagachi (sp?) dial phones maybe.
Absolutely brilliant..........well done!
There are many things that I would like to continue to do as a hobby, but I just do not have the space.
However, I can get some pleasure from seeing what others' have achieved and admire their workmanship.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
    • Welcome to the WRT forum.
