Watch repairer recommendations
51 minutes ago, Nucejoe said:
I think the hour hand is loose, best to uncase the movement, remove the minute and hour hand, peen the hole in the hour hand then reinstal the hands. Dial should protected just in case a tool slips as you press the hands on.
Thank you for your help but never done this before and I am so scared to touch this and maybe make it worse.
Ibought this back in 2020 and it still is going nowhere wrapped up in a case.
Terrible
I reached out to marshall Sutcliffe on YouTube to see if he will have a look but no reply at all.
Can anybody remove the hands ?
Also did you see the picture I posted of the new stem ?
Does that look like the right one?
Shouldn't personally attempt it then.
Need to have number of dimention of its profile to tell.
13 hours ago, Gordie said:
I have no skill to know or repair what is wrong
I think we need a clarification so I quoted something no skills to repair a watch correct? Is this an easy watch to fix may be but it requires skills. It's a Omega watch and as you noted finding a nice clean perfect older Omega watch is a challenge or maybe it's impossible? Having the problems you're having makes you wonder if the watch was really serviced at all. Sellers typically on eBay exaggerate the reality of the situation and usually don't backed up or guarantee what they've sold. Because if it had been recently serviced it should have a warranty and it should go back to wherever it came from.
If you've never done watch repair learning on an Omega watch is not a good watch to learn on. You need to find somebody who knows how to work on a watch and have them fix the problem. Otherwise things are going to really expensive really fast. Because there are not a lot of Omega parts out there.
So to help us what is your watch repair skill level experience? Then can we get a picture of the inside of the watch in other words take the back off?
Hi  What JohnR725 has explained is spot on, without any prior experience the removal of the movement and re fitting of the hands without the equired skill level is frought with problems and as its an omega expensive ones and therefore best left to some one with experience.  Again pictures of the movement and any numbers are always informative.     cheers
  • 4 weeks later...
I have a very basic Seiko quartz (circa 1979) that is not working and looks a bit worn but has a lot of sentimental value.
I would like to find a very reliable person who will thoroughly clean and repair to new condition without removing the scratches.
How do I proceed?
Thanks.
  • 11 months later...
I live in Thailand and have a Corum Admirals Cup with the rattrapante complication and it needs a service. Does anyone know of a watch repairer in Thailand who could do this for me. I have other watches to wear so can be without it or a while (perhaps this complication is of interest to the esteemed Mark for use in one of his videos). The watch is a recent acquisition and I doubt if it has ever been serviced so needs some loving attention as I don't even need to put it onto a timegrapher to see its daily rate is minutes rather than seconds out. There are lots of places advertising watch repair even one in Hua Hin where I live but I am reluctant to entrust this into the hands of an unknown repairer.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
