Hi, I am a new member. My name is James, but I go by Jimmy. I am a blacksmith, with a love of pocket watches, particularly key winds. I do a little tinkering on watches in my collection from time to time. A good friend, and new member, Sterling, knowing of my interest in watches, sent me this link.
Thank you for your introduction and welcome to this friendly forum.
Did you know blacksmiths  used to repair clocks, if no clock maker was about, people would take it to the village blacksmith.
Welcome Jimmy. Does this mean that you apply your blacksmith experience/equipment on repairing/restoring pocket watches ? Would be interesting to see some of your projects.
Thank you, all for the friendly welcome. To answer the questions brought up; no, I am not a farrier, I interpret the blacksmith trade at the High Point Museum Historical Park, in High Point, North Carolina, USA.
My smithing skills don't help much with tinkering with my watches, rather the other way around. Watchmaking has helped teach me patience.
Oldhippy, I am fascinated by the history of the blacksmith/clock maker, and their involvement in early tower clock building and repair.
    welcome James;  i like that image with the anvil,   repairing a Timex ?      vin
  • Haha 2
Welcome, Jimmy. I think you will like this group. I started on pocket watches about 10 years ago. Now, it’s a full blown addiction/hobby! If you have any questions or wisdom to offer, please do. Be sure to post pictures of your project watches.
Hello James my name is Graziano and I am new too, I play around with wrist watches mechanical of course. Gee not many blacksmiths around these days. Good luck champ
Hello Griziano, welcome. It’s a good group. I think you will like us, if you like working on, breaking or restoring watches!! [emoji846]
That would be interesting to see!! Stick that Patel in the fire for a few minutes and see how it holds up....
  • Sad 1
OH knows everything!
Here in the UK the Longcase clock or as many people like to call them Grandfather clocks,  with the very old ones you come across the repairs from a blacksmith, Sorry to say they were very crude in closing worn holes due to wear, they would use a punch around the hole to try and take up the wear. That is the most common find.
    • I'm no expert, but I'd guess this one is for the bin. Looks like it's been tinkered with by someone armed with a hammer and chisel. When the pallet, escape wheel and balance are all damaged it's beyond repair isn't it? Or a new movement if the watch itself is of value.
    • No need for special tools. Loosen stud screw and just push hairpsring stud out of the hole.  Regulator arm is spring circled around the setting housing, insert cutting edge of a safety blade under it,  opposit ( 180 degrees) to regu arm itself, and pry  half of the circle up, you then see how it all is made at put together. Remove the mobile stud carrier as well,  reinstal in proper order, first goes on the stud carrier, second put the regulator arm on top and press it home. Exactly as nev explained above. Trueing inner coils is done when balance complete is seperated from the cock.   The part thats bent over itself. 1-Unbend hairspring as much as you can when balance is seperated, just grab the hairspring stud in tweezers , grab hairpsring with another tweezers streighten with  strokes as you  move the second tweezers  away from the stud. 2-Move stud carrier and regulator arm as wide/ apart as they go , to provide max space which comes useful in next step. 3- Fit hairspring stud, into stud carrier hole. 4- Put balance and cock ( when attached together) back on mainplate.  5- You have enough space to grab hairspring in  tweezers to shape as you move your tweezers  away from stud.
    • Probably more than you need to know in these two vids, but sharing because I found them quite interesting. 🙂
    • And then the problem of the stud holder and regulator which are on the wrong sides of each other:   I am baffled as to how this will have happened?  They can't re rotated into place, the regulator pins stop the spring stud from moving past. I don't think I can remove the regulator and/or spring stud without a staking set?
    • Just to inform that this is not a shock protection, just end stone fixed in place by the spring.
