Hello all!
DanO
I'm a hobbyist that likes workshop time, building mechanical things, and tinkering.  I've always been a watch guy but never really got into gear teardowns and rebuilds.  Even with many years of building CNC machines, 3d printers, and other contraptions I've always been a bit intimidated with getting into watch repair and servicing.  Well, I'm into it now and hope to learn and contribute when possible.
P.S.  I hope my introduction is in the right forum location; if not my apologies.  :)
Dan
Welcome here. I am bit intimidated by CNC and machining in general myself, but after tinkering with my micro lathe I've found that is not much different from working on watches, time flies, little is accomplished, and more tools are always needed.
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
