Where does this jewel get oiled?
Lc130
Hi All
This is an FHF 28.  I'm a beginner and haven't worked with this type of jewel where the cap is screwed in.  There's an oil cup on the other side of the plate.  This is for the escape wheel.  What gets oiled?  The screw in cap or the oil cup or both?
Thank you
Charlie
Thank you for pointing out that issue.  It would not have occurred to me.
congratulations on restoring your grandfathers watch.  I have my grandfathers pocket watch inscribed Christmas 1915.  It’s pretty far gone but I hope to restore after a few more years of learning.
On 12/18/2019 at 4:23 PM, rogart63 said:
You place a small drop on the endcap . It will spread out when you put it back on.
He will also need to oil the pivot jewel holes, if he is using the correct synthetic oil like moebius it does not spread when applied correctly with the correct amount. Spreading is one of the reasons why synthetic oils were invented. Spreading is the one thing we don’t want when we oil a jewel. Too much oil and it will just get whisked away by the pivot. By putting the cap jewel back on it will just flatten the oil bead but it wont make its way into the pivot hole. Again assuming he is using synthetic oils. Hopefully 9010 on the escape.
The BHI document says not to do this. Part of the point of oiling the cap jewel is to get a very small controlled quanity of oil just on the pivot. Putting oil into the jewel hole as well would likely result in too much oil which would then get drawn down the pivot onto the staff.
It’s more critical on the balance, but still important on the escape wheel not to have too much oil.
I can’t imagine oil spreading onto the staff with proper oiling and using synthetic oils. If you are worried about it then you can use epilame/fix a drop. I would not feel comfortable with a dry pivot hole under any circumstance, esp on a balance or escapement.
The standard technique for oiling these, as well as non shock protected balance jewels, is to assemble the cap, put oil in the cup of the underside of the hole jewel, then feed it through with a fine taper pin. It's in numerous texts and is how it's taught in school. You continue to add oil and feed it through (usually it sucks in after the first pin feed) until you have a correct circle of oil showing on the cap jewel.
Oiling before assembly runs a great risk of smearing it elsewhere, which really requires a full cleaning of the components then. Dabbing with Rodico is not nearly enough.
That’s actually how i do it now, because i have seen marks videos and he oils the cap jewels then the pivots before assembly and if you don’t get the cap jewel in perfect the first time it smears and gets oils around the cock hole. I use the Bergeon automatic oilers for this and I don’t need a pin, i can see the bead form on the cap jewel with the microscope.
Edited by saswatch88
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
