Introducing myself - Jody
JWSimm11
Hello everyone,  My name is Jody and I am in San Antonio, Texas.  I became interested in watch repair a few months ago when I sent my  Longines Conquest chronograph purchased in 2012 to a watch repair guy because the chronograph pushers are frozen.  His diagnosis- replace the mainspring for $540 dollars-  it keeps perfect time....  when I received it back the case back fell off... it wasn't even tight! I question that diagnosis so I to do some research on mechanical watch repair.  This lead my Mark's videos and I was  hooked after watching the first one.   I am now working my way thru all of his videos... a new passion!!  Below is a picture of my watch after the back fell off.
Hi Jody welcome to the forum. Sounds like you have had a bad experience.  Pushers seize up due to ingress of water swat dirt, The fix the problem the movement has to be removed and then the pushers which contain small clips and springs. If you van supply photos of the movement and  the caliber number we may be able to find the tech sheet for your watch. It will give you a better understanding of what it comprises of before taking it apart.
He was probably "disappointed" that you didn't feel for his attempt, and so returned it hastily. You can check his professional affiliation looking at the AWCI directory online.
2 minutes ago, yankeedog said:
Pushers? You could remove  the movement  from the case and wash  it in hot  soapy  water.it would  most likely  free them  up.rinse in distilled  water allow to dry thoroughly  before reassembling.
Wash the  case that  is.
I'm a little hesitant to open my watch.  I saw a quote somewhere that said something to the effect of..."don't practice/learn on your own watch".  My regular watch guy retired last month at 82.  He serviced my watch 3yrs ago and fixed a loose screw that was preventing the autowind pendulum from swinging... charged me a grand total of $35 dollars.  I may just send it to Longines,  they offer a full service including polishing the case and bracelet for $390.  I may try operating the chronograph manually bypassing the pushers,  that should let me verify it's the pushers and not the movement itself.   If I do I will post a video of my efforts.
Interesting. What I see in your video is a phillips head screw holding the case clamp at an angle. I also see the case ring rotated a little. The stem should be centered in the cut-out part of the ring and the case clamps should be straight. I agree with Nucejoe --  I wonder if when your loose screw was replaced , the case ring shifted enough to block the pushers?
So,  I was able to manually start, stop, and reset my chronograph.  I then went back to my jeweler who recently hired the two questionable people that said i needed a new mainspring.  We open the back,  he loosened the screws and adjusted the movement ring... and like magic the pushers began working as designed.  Saved myself $540.  Thanks to Mark and all his great videos because my jeweler is just that.. a jeweler and only knows how to change batteries.... but he has an AWESOME SET OF TOOLS
P.S.  Hey Mark,  kindly do a Public Service Announcement concerning ''CHEAP WATCHMAKER TOOL KITS".   It did serve on great purpose...I realized you need to actually spend a little money if you want decent tools....  <Lesson Learned>
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
