Introducing myself - Jody
JWSimm11
Hello everyone,  My name is Jody and I am in San Antonio, Texas.  I became interested in watch repair a few months ago when I sent my  Longines Conquest chronograph purchased in 2012 to a watch repair guy because the chronograph pushers are frozen.  His diagnosis- replace the mainspring for $540 dollars-  it keeps perfect time....  when I received it back the case back fell off... it wasn't even tight! I question that diagnosis so I to do some research on mechanical watch repair.  This lead my Mark's videos and I was  hooked after watching the first one.   I am now working my way thru all of his videos... a new passion!!  Below is a picture of my watch after the back fell off.
Hi Jody welcome to the forum. Sounds like you have had a bad experience.  Pushers seize up due to ingress of water swat dirt, The fix the problem the movement has to be removed and then the pushers which contain small clips and springs. If you van supply photos of the movement and  the caliber number we may be able to find the tech sheet for your watch. It will give you a better understanding of what it comprises of before taking it apart.
He was probably "disappointed" that you didn't feel for his attempt, and so returned it hastily. You can check his professional affiliation looking at the AWCI directory online.
2 minutes ago, yankeedog said:
Pushers? You could remove  the movement  from the case and wash  it in hot  soapy  water.it would  most likely  free them  up.rinse in distilled  water allow to dry thoroughly  before reassembling.
Wash the  case that  is.
I'm a little hesitant to open my watch.  I saw a quote somewhere that said something to the effect of..."don't practice/learn on your own watch".  My regular watch guy retired last month at 82.  He serviced my watch 3yrs ago and fixed a loose screw that was preventing the autowind pendulum from swinging... charged me a grand total of $35 dollars.  I may just send it to Longines,  they offer a full service including polishing the case and bracelet for $390.  I may try operating the chronograph manually bypassing the pushers,  that should let me verify it's the pushers and not the movement itself.   If I do I will post a video of my efforts.
Interesting. What I see in your video is a phillips head screw holding the case clamp at an angle. I also see the case ring rotated a little. The stem should be centered in the cut-out part of the ring and the case clamps should be straight. I agree with Nucejoe --  I wonder if when your loose screw was replaced , the case ring shifted enough to block the pushers?
So,  I was able to manually start, stop, and reset my chronograph.  I then went back to my jeweler who recently hired the two questionable people that said i needed a new mainspring.  We open the back,  he loosened the screws and adjusted the movement ring... and like magic the pushers began working as designed.  Saved myself $540.  Thanks to Mark and all his great videos because my jeweler is just that.. a jeweler and only knows how to change batteries.... but he has an AWESOME SET OF TOOLS
P.S.  Hey Mark,  kindly do a Public Service Announcement concerning ''CHEAP WATCHMAKER TOOL KITS".   It did serve on great purpose...I realized you need to actually spend a little money if you want decent tools....  <Lesson Learned>
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
