Namaste From India!
Sid
Hello All,
Greetings.
This is Sid. I am from India. I am an Information tech. professional and an aspiring watchmaker.
I am fascinated by mechanical watches and addicted to the science of precision (I am a complete beginner though and know nothing about machining yet)
Two years ago in my wildest imagination, I saw myself making watches by hand and began a quest to seek right tools, right people and right places to bring my imagination to reality.
When I recently visited this forum it felt right to be here so, I joined it yesterday.
I am excited and hope to get to know you better.
Cheers and Thanks :)
1 hour ago, AndyHull said:
Hi and pranam and welcome to this friendly forum,
As you are no doubt aware, India has quite a number of current and historical watch companies. I look forward to seeing your progress in building your own watches.
Kind regards
Andy Hull
Hi Andy,
Thanks for encouragement and a warm welcome.
2 hours ago, Nucejoe said:
Hi, Welcome to WRT forum.
Master watchmaker who made bunch of prototype parts for this, helps and gives advice on this forum.
Or was it one looking jusg like this?
Is there a video of this timepiece posted somewhere?  I've only seen stills.
And, welcome to the forum, Sid.  Fine fellows here.
I don,t know, surely master watchmaker dose.
I guess the movement alone is a prototype and what better than a transparent case to give a sepherical view all around.
21 hours ago, Colditz said:
Welcome Mr Sid sir
I am also interested to see the watches you have in India. I am sure the rest of WRT members are also.
Do you have a collection or the start of one?
Thank you Mr. Colditz.
I primarily collect watches so that I could strip them down and put them together.
I also have a small collection of 30-35 watches which includes..
Indian - HMT, Allwyn, Titan
Japanese - Seiko, Citizen, Orient, Orient Stars
American - Timex, Invicta
Swiss - Tissot, Tressa, Favre Leuba, Titoni, Victorinox
Chinese - Seagull 1963
Basically all entry level, NOS and common vintage watches of the 60's - 70's.
Best,
Sid
  • Similar Content
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
