Making the micro regulator adjustments
I would like to hear the various techniques for making the fine regulator lever adjustments and beat adjustment, when available on the upper side of the balance bridge.
If you get within 0.8ms in beat, what are you doing to get it tweaked to 0.1 to -0.1 ?  I use a double loupe magnification on my reader glasses and sometimes seem to go too much one way and then again too much in the other direction when fiddling with this.
Thanks,
George
Most likely, most of us are like yourself, it's like a dance.
I try to brace my hand and use a twisting motion with the tool rather than a push to move in very tiny increments.
Also I recommend restarting the timegrapher after an adjustment and allowing a few seconds for the amplitude to settle.
Great thought.
To prevent any marks from a tool such as a metal screwdriver, I could fashion a plastic pixie stick or a piece of peg-wood to a flat end and give that a slight twist for control. Thanks
10 hours ago, m1ks said:
...Also I recommend restarting the timegrapher after an adjustment...
Why do you recommend restarting it? I'm going to buy a timegrapher, and I was thinking in a weishi 1900 instead of the 1000, just because I've read that the dot lines in the graphic are dual color, helping in setting the beat error as you will notice if you've gone too far in the adjustment. But if restarting is a recommendation then I don't see any advantage against model 1000.
Edited by aac58
My reason for restarting:
I am using the 1000 model and after attempting to adjust beat error, with a +-3 s/day watch as an example, I may be trying to adjust beat where the graph will have one line on the top edge of the display and the other on the bottom.  I can stop/start the machine and get the graph back in the middle of the display for better reading.
Apologies for not clarifying re the timegrapher but first, I should also have mentioned, I use a piece of pegwood, (one end a point, the other a flat edge like a screwdriver) to adjust the regulating arm, for the aforementioned potential problem of leaving marks.
Restarting isn't necessary at all, just that it seems to take longer to pick up the difference if left running than if you press stop then strart, I haven't timed it, it just seems that way to me, but either way, you'll need to allow a few seconds for the beat to settle back into a smooth rhythm.
The dual coloured lines are useful, and even restarting will still work, you just note whether the blue or the yellow line was uppermost. I find it useful because if you go from a small BE like 0.5 to 0.3, you could 0.3 on the opposite side and the lines are so close you can't tell on the screen so the split colour helps.
Instead of pushing on the regulator, try little sideways taps. Here a screwdriver works better than pegwood. Little taps, not hard knocks. This works for me when chasing the last few ms.
Good luck.
Anilv
Good advice!
Problem is the higher sticking friction against lower sliding friction. The force needed to break the regulator arm free is higher than the force needed to move on the sliding arm. Pushing, you cannot avoid to push too far.
I made a tool (slotted brass rod with a big radio button on the upper end) for better feeling:  the mentioned problem gets a bit smaller but is still there.
Now I mainly use a screwdriver with brass blade and tap with the back of my tweezers.
Thus you always apply a limited amount of energy and overshoot can be avoided.
Frank
Another idea that may work, when the regulator arm extends over the cock-plate, would be to have a brass screwdriver blade size 60 or 80, and place the edge just under the side of the regulator arm and pry the arm in the direction desired by raising the screwdriver handle up in a leveraging method.
I don't have a watch currently to show an image of but I've put this image together.
micro_regulation.png?raw=1
Edited by GeorgeC
edit image text explanation
    • My mentor has been using one of the Chinese clones for several years. Seems to work very well. Just put the object you wish to demagnetize in the centre of the cross and press the button. One word of caution though, the quality and QC of Chinese clones can vary a lot. You'll never know whether you got a gem or a lemon.
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
