Timex indiglo light
There is a possibility that the battery contacts are not very clean.
The watch movement would be less likely to be affected by this as it draws very little current, but a higher resistance in the contacts might be enough to stop the light from glowing.
LEDs do fail, but typically last several orders of magnitude longer than old fashioned filament bulbs, but white LEDs require a minimum voltage before they will light, somewhere of the order of 3.3 Volts, and in a watch that uses a 1.5V battery, this is produced by a boost circuit. The circuitry needs a relatively high current, typically 10 to 20mA compared with the tenths or hundredths of a mA, or even a few uA  needed to power the movement of the watch.
Some glowing watches use electroluminescence, and this also requires a voltage boost, and a relatively high current to make it work.
Try carefully cleaning all of the contacts including the presser for the light with contact cleaner or alcohol and see if that helps.
This link might also be useful.
Edited by AndyHull
  • 6 months later...
30 minutes ago, HonorPaul said:
Hi there, Ive just purchased a Timex Easy Reader and the indiglo is not lighting up at the 6 o clock position.
Just wanted you notice that we have a watch repair section for questions, this one should be for  everything but watches so this thread was also posted in the wrong place.
  • 3 months later...
Hi   if the watch is working ok it could be that the substrate of the dial is u/s or insufficient voltage is being applied.     This is a thread which has been docmented beforeon the site. Look up previous threads on the subject using the search window. to avoid repeating ourselves.    Cheers
    is it posible to find a easy way to locate old threads via subject?   vin
Most of what you need is in this thread. The one other thing I would check first, If there is a separate pusher for the light, then I would suspect the contacts on that pusher. Try giving it a clean with small drop of contact cleaner. Also make sure the battery contacts are very clean. The high resistance of dirty contacts may not stop the movement, but it may starve the boost circuitry for the EL light.
If the search function on this site is not getting you the results you need, try using Google with the "site:" verb. Something like this...
wombat site:watchrepairtalk.com
Substitute "wombat" with whatever you are looking for, so for example
In the google search box type..
timex indiglo site:watchrepairtalk.com
This trick works for pretty much any search term (and of course any site, not just wachrepairtalk.com).
See here for even more google trickery.
https://www.google.co.uk/advanced_search
Edited by AndyHull
  • 10 months later...
I do not know if every indiglo watch work the same way, but I recently cleaned up one where the light did not come on. The reason why it did not light up was because an incredible amount of dirt was beneath the crown so the crown could not go deep enough to activate the switch on the side of the movement marked with red. I advise to replace the battery and operate the switch manually with a pegwood/plastic etc so you would eliminate the battery and crown issues.
This is what I found on the web about the light:
"Timex received the patent for the Indiglo® nightlight in 1988. The nightlight's bluish green light illuminates the entire dial of the watch evenly at the push of a button. The dial is coated with a compound of zinc sulfide mixed with copper, a substance which becomes luminescent when an electrical charge is applied. This layer is sandwiched between two conductive layers which act as electrodes. When the button is pushed, energy is supplied by the battery across the two electrodes, which in turn lights up the dial."
More here: Timex indiglo light
Edited by luiazazrambo
    • Just missed it! I have a donor movement on its way. But thank you for the offer--I'll let you know if I need anything else.
    • My latest. Timex 2465. Replaced the crystal, caseback gasket and spring bars. All in less than $5US. Added a gray NATO strap I already had in stock.
    • I have some Gruen 510's in my donor pile if you need parts.
    • I've been intrigued by everyone's input here...so I decided to give this a shot. I bought the"typical" Pearl watch-machine basket and trays, for about $65. The trays are good,..the housing is a nightmare ! Thought it would take the mixer off my bench at anything above about 200rpm. The housing is cast of course,..and it's not "true" at all...so the harmonic vibration was insane. So,..I bit the bullet and bought the Elma housing and top. Not the baskets though, as the Pearl one's fit the Elma. Saved a bunch there. The basket and lid came to about $80 with shipping. The opening in the Elma top is 8mm, and the shaft that came with my stirrer is 6mm. I bought a piece of steel tube, 8mm O.D., and 6mm I.D. Cut off about an inch of the tube, and drove the rod into it. Gives a really snug fit.... Lightly champfered the leading edge of the 8mm section, then lightly tapped it into the top of the Elma lid. Spins like a dream now So... I have about $240 total into this including jars and steel mesh for the wave breakers   I'm pretty happy Best to you all   Randy
    • Still haven't gotten around to getting stems or screws, but I did make my first attempt at polishing a case. I just used a soft mop and rouge to reduce my odds of ruining them, and I think they came up pretty nice. Also gave the crystals a polish on the same wheel while I was at it. They were both very badly scratched up. The one on the left is fairly beat up, but it'll still make for a decent presentation.
