Hopalong Cassidy - NOS Replacement Strap
JerseyMo
No, I don't collect the vintage character watch series made by US Time and Timex.  But I have restored a number of them and typically the strap is missing or well worn.  Some had very distinct straps and trying to find a suitable replacement is not easy.  Ah but, what if you could find a NOS?  Not so easy to do and I thought I never come across one for the Hopalong Cassidy.
You know the one with the big buckle and metal tip.  Than I get in a huge NOS lot from a retired salesman and found this >>>>
Edited by JerseyMo
typo
  • 4 weeks later...
Some things are just meant to be and that strap had your name on it. Well done!
Is it just me but, somehow I feel a little sad when I have to separate the strap from an old watch that have been together for goodness knows how many years. I have just stood in front of the waste bin with the strap from a watch that has been worn to the point it had assumed the shape of the owners wrist. The fastening hole was elongated by many years of use. I felt genuinely guilty about letting it finally drop into the bin. I can’t help but think about the person who might have owned it, the places it has been and the stories it could tell. I think I must be getting more sentimental with age.
You could, of course, attempt to restore the strap. Some of the leather ones I've encountered did actually restore quite nicely.
I even re-stitched a couple of them. Others however are so badly worn that they are beyond hope.
1 hour ago, Davey57 said:
Yes I have rescued one or two, but some are so disgustingly ingrained with “stuff” I could not bring myself to use them.
yep, as with all straps and bands there can be some seriously funky stuff growing in there!
  • 2 years later...
I cant say I had no difficulties. I was ready with the one you can see on the pics once then i was checking its performance on the timing machine it looked brilliant so i tried to regulate it while i was working from home. Just a light touch with my tweezers reaching it over my computer.... my tweezers slipped and i literally destroyed the HS. I was so sick I could not revisit it for about two days. I sourced another HS and as far as I remember I also ruined the pin pallet while I tried to clean it so I had to source that too. (the pins were stuck in rodico and the rodico pulled one of them out when I tried to lift the fork up, i put the pin back but it was not tight enough anymore) You can buy ladies watches with M21 on eBay for about £2-£4 as a donor movement. I have serviced another M21 since this one and another two M22s are on my desk. Just like with anything else everything gets easier/quicker to handle if you practice it. Originally I could not even imagine how to put the main plate back and now I don't even consider it as a difficult task, it usually goes back all right for the first try.
Edited by luiazazrambo
11 hours ago, magic2020 said:
Got one just like that as a present in 1956  (I'm 75), but hesitant to do anything with it in case I fail miserably!
Maybe one day?
If you need advice or parts let me know I am going to try to help you the best I can. Take care.
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
