Pegging jewel holes
Lc130
As above, definitely use pegwood. I find that the quality of the pegwood makes a significant difference as well, some grades are easier to sharpen to a perfect shape. The indian orangewood sold by cousins, although a step up compared to toothpick, is not up to the job for small jewels found in watches.
Amen. I’m on the lookout for a much better quality pegwood so if anyone cares to mention a source in the UK or Europe I’m all ears.
Anyone sourcing folks with a majic pegwood up to the job, would make a living by it.
I join hands with pip, Thank the lord for the pegwwod we are about to receive.Amen.:jig:
Is indian orangewood a label? brand name? Or tells  the wood is off of some type of indian orange tree. If so plenty orange trees in my front yard so all I need is a pencil shrapener:lol: .This is got to be the stupidest question ever on forum.
BUY? being a Scot (now in Australia) why buy pegwood, just get a scrap bit of oak, ash, whatever as long as it is hardwood, use a tennon saw and cut it into about 1/4 inch squares, and chisle the end to the size you need. Failing that I have also reused Kabab stickes after a BBQ. :biggrin:
  • 7 months later...
Just took a look at the Cousins website. They have the Indian orangewood as mentioned by Oli above, the German orangewood he recommends, and swiss beech or hornbeam. All are at the affordable end of the scale. Then there's the luxury article from Horotec, which is described as Swiss gentian wood. I guess this is the sort which Nickelsilver praises above, in which case I assume the price is justified. I'm looking for something which will take a really fine, sharp but durable point, but still clean well.
Wouldn,t that be nice.
The gentian wood would be really fragile, it's close to pithwood in consistency. Great for polishing bevels, not much else.
Regular pegwood is light years beyond toothpicks, the "normal" horotec i described above is a-ok for jewels down to say 0.07mm no problem. You should peg the pallet hole jewels if nothing else, a good 30-40 degrees of amplitude lie there!
A bit of drift but still related to pegwood.
I have a table pencil-sharpener bolted to my desk. I use it to get a nice conical tip and then use a knife to get a fine point. If I hand shape the point I find I really need to focus on getting the tip central otherwise it wont spin concentric when you roll it between your fingers. Te sharpener does 95% of the work and I just contribute the last 5percent.
Note, while you may get by with a hand sharpener, the table type ones hold it  central better.
Anilv
Try getting yourself a couple of mechanical drafting pencils and a sharpener. These can really put a fine point on pegwood as shown in the photo compared to your standard No. 2 pencil out of a desktop sharpener.
sharpener.thumb.jpg.49a5bddfbb81972d6d199761fc1e9100.jpgS20191103_0003.thumb.jpg.76a33e311b2158f993c53203317b1278.jpg
Edited by eccentric59
    • Yep, i pulled that up as well when i was looking,  there is definitely parts out there if you are prepared to go out and find them.  I watched that video years ago, I'm not so sure about probing the coil like that. If you are going to touch the coil use the side of the probe or at least shape a nice round end to it.
    • Hi and welcome to the forum.   As you are already familiar with watches the attachment you may find useful Witschi Training Course.pdf
    • I saw this listing from Australia this morning on Ebay, it might be your only option, good luck.... https://www.ebay.com/itm/145735044565?itmmeta=01HWCRFPEYDDTCXYCRX7ESQH3K&hash=item21ee7c4dd5:g:f2oAAOSwaMhmI5tq&itmprp=enc%3AAQAJAAAA4PzZAWzJj0HOwVM7Xl6qUqGIYly3BvZhzNybkxWf8GJYkKwVh0SpeZ0XYBmoZyjaboPOlJYzdY9svwhQXfR7V%2BiMApTEYFLvJcs8FxTzy1VFCBLR8ADc7V89%2B%2FYvQKdks2KDNNEqAFZN0Hni9zQG078wKL34x0eRK%2Fu843fYdH%2FVIAiOZ5%2BbOmySNdu%2Bv4cSemywC%2FWfaiI%2Fj5D3YWk2PaySdPfu7lUaMadcyhmHZM6l6NllJd1eK%2BdblkJD98pTzVuxRDne5AQaCYawls%2FaoQK9B7epV%2B87TIbD9Ulr4qdC|tkp%3ABk9SR-rnvpjjYw
    • Hi. In the picture not only does it depict that the wheel is bent but also the plate or is that due to th angle of the picture.  Already received very good advise so I will butt out.
    • welcome, sounds like you are on your way so far, you also might be able to help with gold/plated case repair for some .....
