ETA 2892-A2 Automatic Works - what else can I do?
By SwissSeiko · Posted
Lubed up, back together (minus the one screw), and I'd say not a bad result! Going to give it a day or two to run in while I clean up the case and regulate it again, but off to a good start. -
So it runs and keeps good time even with that train wheel. You are lucky I would point out to the owner about the wheel, just in case at some point they take it to a different clock maker.
