hello everyone....
Ianh
Hi everyone,
I am a newcomer to the world of watches and watch repair.
I recently came across a lot of old watches(and a pocket watch) at my parents most of them timex from the 1970's and thought it would be nice if I could get these going.
I have done some research and managed to get movement numbers and dates from the small numbers at the number six position.
In total I have six watches that I would like to get back to working condition.
I have stripped one down taken dial off and hands and soaked it in cleaning fluid dried it off and it burst into life,just got remember how it goes back together!!
so over the next few weeks I will be asking a few tech questions and hopefully get the others working.
thanks
Hi,
I'm Jon, I'm new here too.
Good to hear you're having fun with taking apart a watch and breathing life into it again. I find the Timex watches hard work to work on, as most of them weren't designed to be serviced per se. They are riveted closed and don't have jewels, even on the pallet fork, they are just metal pins, that's why they have that particular sound. Not to say don't work on them. I got one going the other day that used to be my Dad's with a few drops of oil. You just might find a watch that was designed to be serviced and had a good movement with jewels more enjoyable. I've just bought 10 on eBay for about £30. All mechanical hand winding..
Well, that's my thoughts on Timex
sorry but, I do not understand why this comment of Timex movements being riveted and non serviceable is so prevalent.  I have worked on thousands of them using the guidelines in the service manuals aided by some homegrown techniques. As for no jewels, that is also not on point. Their are serial 17 jewel movements used and even 7 in the electric models.  It can even be said that the end cap on many of the  M24 is actually a synthetic jewel and not metal as the rest of the movement is.
Well anyway, if you need any help with the Timex just LMK.
quite true that Timex is not easy to work on if you take the traditional approach of a full tear down service.   But, they actually do not require full tear down unless it is confirmed that parts are damaged.  Even at that point I no not recommend full tear downs unless you have a ready supply of NOS parts and are willing for it to end it total frustration :)  Given that there were millions of vintage Timex made it just much easier to find a donor rather that work on a movement that won't quite get back to working order.
1 hour ago, Ianh said:
Thank you for the welcome, I’m about to assemble one Timex as we speak no doubt will need guidence as I never took any pictures before I took it apart!!.
Do I start a new topic if I need help?
Thanks in advance
would be easier to read a new post with just the repair itself.
5 hours ago, Jon said:
Hi,
    yes;  timex pates are rived together.    did you know the early ones were screwed together? this allows  complete dissasembly?  there a few of them still around.  vin
Edited by vinn3
add welcome note
Thanks in advance
If you can identify it's calibre I can probably post it's tech sheet.
    • Hi Bob, Welcome to the forum and thank you for your service.  I would never try to discourage you from getting into this wonderful hobby/profession, but please be aware, it does not cost just a few dollars to get into watch repair.  Tools are expensive and in many instances the cheap knockoffs are worthless, especially when learning.  You can get the tools needed to disassemble, clean, inspect, reassemble and lubricate a watch without spending thousands, but as soon as you start getting into task-specific tools, there are so many and they don’t come cheap.  My suggestion is to start with the basics required to disassemble, clean, inspect, reassemble and lubricate only, and build upon that gradually as the need for other tools arises.  The advice above regarding starting out on working movements is gold. Many of the non-running watches on eBay have been bought, tinkered with, deemed too difficult and then sold again, often with more damage done each time.  Without experience, you clean and service a non-runner and it still doesn’t run. What now? Troubleshooting is difficult as a beginner. This can become very frustrating.  I would encourage you to buy a working movement, and learn to strip and service it. If it isn’t running afterwards, you know it’s down to you, and as long as you didn’t damage anything you know that the parts you’ve got can form a ticking watch. An excellent movement to start with is the ETA 6497 clones from China, such as the ST36. They’re not expensive, and although it finds use in some larger wristwatches, this movement was originally designed for use in pocket watches, so everything is larger and easier to see and handle.  Once you can service a new ST36 and have it running better than it did when it arrived, you’re definitely ready to step up to working vintage watches and then think about repair of non running or poorly running watches.  As far as cleaning solutions go, you will not do better than the commercial watch cleaning and rinsing solutions that are available. You’ll find plenty of suggestions for home brew cleaners online, but the professional products are superior and you want to give yourself every advantage you can, especially when you start working on vintage movements containing hardened decomposed lubricants and often years worth of other dirt and dust. Alcohol is ok for cleaning or rinsing movement parts that don’t contain any shellac. The pallet fork and roller table contain jewels secured with shellac and will tolerate a rinse in alcohol but not prolonged exposure. Methanol dissolves shellac faster than ethanol, and isopropyl alcohol dissolves shellac slower than ethanol. Just in case you don’t know already, the radium on the dial (and likely the hands) of your Dad’s Elgin is highly radioactive. It is safe enough when safely contained within the watch case, but the moment you open the watch and especially when handling the dial or hands you must take precautions against inhaling or ingesting any radium.  Best Regards, Mark
    • I have both sets and use the K&D 99% of the time.  Yes, you have to be careful with the pin.  I use a screwdriver to carefully release the pin from the spring.  Some skill is involved.   I have also modified/replaced the pins in the arbors as necessary.  Yeah, you would think a tool would not require modification, but such is the world of watchmaking.  There is no perfect tool.  Each watchmaker must the tools to his skill, or vice versa.
    • I have the 8-11mm K&D but it doesn't do a great job with modern mainsprings, or I have had terrible luck. The arbor pin protrudes too much and I have damaged more springs trying to disengage the arbor than I have successfully wound and inserted. It seems easier to use with old carbon steel springs. My Watchctaft set gets far more use, though I have to get creative to wind left hand springs
    • It depends on what the gaskets are made from but silicone lubricant should work.  Spray or rub on a generous amount, put in a sealed bag and wait a couple of days.  Test for softness and wipe off the excess.
    • For hardened gaskets, an experienced watchmaker told me he usually found heat to be the best to soften them up. I tried that on a '70's Tissot where the gasket had turned to essentially epoxy to no avail, but eventually got it off with a 5700 case back opener using a crowbar for leverage to turn the wheel.
