So I have this Chinese movement, it's really nice, horrendously overoiled, partially my fault when I first got interested in watches. Now I took it apart to see why it was acting up. I'm different positions it would either gain a few minutes a day or lose a few minutes so I wanted to get it working nicely again like I had it.
I think the escape wheel moved while I was disassembling. I reassembled and it won't move. Any help is appreciated, just want to make sure my assumption is correct before disassembling it again. If it's an easy fix then I'm hoping not to disassemble it because it's a pain.dce62fd789bb67e2200a528b4a89721c.jpg080187d48746a9b598ac3efb55edac52.jpg6207e1d7cc66fd2644978d93d854b10f.jpg
Sent from my Z956 using Tapatalk
Are you sure that you have all the pivots installed correctly?
If you have a wheel out of place and one side not in its pivot hole that would stop it working?
No the pivots are fine, that one is shorter to fit into the train bridge. Everything meshes good, it all runs but it's like the escape wheel isn't properly locking with the pallet fork. When it's out together all the gears run fine, the balance wheel ( it's open heart) spins nicely, the pallet forks move but the escape wheel doesn't seem to want to. It will Rick back and forth in the pallet fork.
Is the train bridge on too tight? Or perhaps did something get into it? I've taken it apart and reassembled twice. The only other thing I don't have the oils yet. Is it that much of a difference? It was overoiled.
My goal was to be able to properly reassemble then make it a hand wind because it has that and leave the rotor off. Thanks again for any help. If you require more pictures I will try. My camera is very finicky.
Do you have the palate fork upside down?
It was because the train bridge was too tightly screwed down. I unscrewed one of the screws a bit and it started right up. But then it spun out completely so I removed the train bridge to see if any damage was done and got lucky, then I went to replace it and lost both the screws! I'm furious with myself for being so careless. I finally had it too. Can I just buy like one of those sets of screws on the bay? Will it be in there you think?
Hi Mattaphysics,
The train bridge screws are supposed to be tightened fully. If the watch works when a bridge screw is loosened then there's a problem. I would guess a bent pivot.
You need to remove the balance and pallet fork, wind the barrel a bit and observe how the wheels move. If you can't identify the problem wheel then you have to dismantle everything, install one wheel, tighten the bridge and check that it moves freely when blown with a dust-blower. Check all the wheels and jewels.
Anilv
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
