An introduction.
Colly
Hi everybody. New to the fascinating world of horology and just bought my 1st semi decent watch.
....a seagull . An avid watcher of the YouTube watch channels and blown away by the skills in the creation of timepieces.
Got here by following the links on Marks repair of a Breitling that was rusted and hope to learn more about watches in general.
Just a new fan to this amazing theme of creation of mechanical movements and soak up all the history of it in general.
        Colin.
  • 1 year later...
  • Similar Content
