My First Staking Set Advice
I don't know the details of their production set-up, but for small batch production 50 USD seems not unreasonable for the set. The photos are excellent. The parts appear to be very well made. It should be clear now how they all work together.
So how would that give you the end play from the screw down crown? That is a bit on the pricey side. I wonder if it's possible to drill the second hole yourself in a normal split stem?
Can't you solder male and female parts of the stem together, it'll do as a one piece stem.
