Which one would you like and why
oldhippy
Id go for the second of the two good quality french movement in a interesting case, the Angelus is a modern clock produced I would say sometime in the last 30 years and although Angelus being regarded as a good maker it lack's the quality of the second of the two it is definetley not a antique clock.
2nd one because it's cheaper :)  Neither are very old I suspect (they both say "made in"... which to me in a hint). I wouldn't buy either of those.
The first one looks modern, no natural corrosion anywhere.
The second one has 2 different styles of hands, some clearly replaced parts, looks a bit older..,
the Angelus looks like a fairly modern reproduction no discoloration of the enamel dial also the brass shows no sign of tarnishing.The second clock shows lots of age discoloration and the hands on the dial are not a matching pair. But ideally, you need to look in person to see the movement to know for sure.
It would be the second one for me, battle scars and all.  Whether the parts are correct for the case I don't know, but to me it is an old movement, pinned together and has a look of elderly quality.  A bit like yourself OH! :)
PS The pendulum has 3606 lightly scribed onto it which appears to match the number on the movement.  This probably indicates it's original to the clock.
The correct name for these original clocks is French Four Glass Clocks. Most come with a mercury compensated pendulum this means the effect of the weather will not affect the time keeping. Many have visible escapements. They come in various cases from very plain to extremely decretive and can be quite valuable. Most movements are striking on a gong or bell, although I have come across Timepieces.  I have included a photo of a nice decretive one so you can see what I mean. They would have been made from around the 1860 to about 1913 certainly not in or after WW1. Correct about the pendulum it should have the same number as the movement.
The Angelus is a modern clock and it has a bim bam movement or ting tang, two bells and two hammers and has little resemblance to the original apart from the shape of the case, it even has those terrible clips to hold parts on such as the clip holding the bell in place.
It would be the second one for me no hesitation at all.
Thanks to all for taking part.
Late in replying, but I'm please to say I would of gone with the second one too, the screw on hands, nasty C clip and the general 'not old' look of the first one put me off, not to mention its hard to say, but it does look like it has cracks in the glass on the pendulum.
43 minutes ago, clockboy said:
I got it wrong I am was really surprised that the movement with a mercury pendulum has such a basic movement.
Thats why I am a amateur I suppose. B)
They are extremely good movements made with very hard brass and steel.
12 minutes ago, clockboy said:
Agree I have serviced / repaired many of these movements and they are really well made.  I just was expecting something better/unique.
I'll see what I can do the next. I'm always looking for something different but not to difficult to keep the clock section interesting.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
