Sell movement parts?
Got about 2 kilos or 4 pounds of watch movement parts from a friend? Have no idea what i should do with all that stuff? All kinds of parts. Mostly inexpensive stuff i think? Haven't found anything yet so i can retire and live i Jamaica :)
Can i sell it to some store that sell movement parts? Do Kudarsson or Northen Watch &clock supplies  buy in parts? Or any other places?
Or if you have any other ideas i will be happy :)
I am never going to work on all this watches in a lifetime .
I don't know, I'm kind of in the same situation myself. I have several kilos of old swiss mainsprings that were dumped from a material system that I'm not familiar with,  but the pack rat in me couldn't pass them up. I have not idea what I'll do with them. Maybe some day I'll sort through them.
Hang on to them.
sort through them and catalogue them by movement, then you know what you've got.
As a source of spare parts, jewels that can be harvested, potential projects for a rainy day, etc. you will have an invaluable resource
Have them in a big box.for now. I dno't think that is is much i can sell. Put some FHF 30 parts up for sale on Ebay. That's it
Lot of parts for small movements that is hard to sell i guess? Like FHF 190. Lots of parts that says HS on the labels. Don't now what that could be?
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
