Snap on case back
How do I get a "hard to snap back on" case back on a watch. I have tried a crystal press. Pushing against a desk edge and I have even prayed. This sucker just does not want to pop back on???
How did you remove the caseback? If you used a case-back knife and it came off without unusual circumstances, please continue:
First take a close look at the caseback and the watchcase and see if there is anything obstructing placement. You will  certainly need that crystal press, and choose a die that fits just over the crystal, but doesn't overlap onto the watch case or  especially the lugs--it should sit just around the crystal on the bezel. Place the watch with caseback in position onto the platform. A piece of cloth or paper towel can be placed between the crystal bezel (which is facing up) and the  crystal press die to protect it (mine are aluminum, some are nylon). Micro-adjust things so that the die and the bezel are just right and the caseback is lined up with the watch case. Apply gentle, then increasing pressure until you hear or feel the caseback pop in place.
J
Can't get it back on. I have tried everything
OK then....time for pics of caseback front and back, and a close up of the watch case itself.
J
Sent from my SM-G925T using Tapatalk
the mvt.  may have moved out of place,  or - if there is a notch in the rim of the case back - it goes over the setting stem,  hope you got this info before it was crushed,  cheers vinn
Knew that but thanks
Sent from my GT-N5110 using Tapatalk
J
So pi__s _d off at this , I'm just going to visit a local watch maker with perhaps a high end press and just get it done
Richard,
A snap-back case consist of two parts with a 'lip' or even a taper.
What usually causes snap-backs not to 'snap' back in place is a slight distortion in the case back. Place the caseback on a flat surface and see if it 'rocks'. If it does you need to fix it by applying pressure locally. Use blunt tools, sharp tools are no good here. I have use a piece of card-board to fix this. Place a piece of cardboard about 5 mm wide on a hard surface, align the high spot so that that is sits on the cardboard and apply pressure on either side. Finger pressure is usually sufficient.
In some cases, the mating surface on the case and caseback may get bent/distorted so that they don't 'snap'. Judicious tapping with a hammer can usually expand the metal sufficient enough so that it 'snaps'. This is not so common and proceed with care.. you just want it to expand a bit otherwise you'll have problems getting it off in the future.
Finally when it comes to base metal cases... the metal gets eaten away until it will never snap back. The case is junk. I've seen cases glued with araldite, JBweld etc but this is not proper horology and besides, having chemicals next to you skin is never a good ides.
All the best!
Anilv
Richard,
All the best!
Anilv
Great tips. I think it is flat but will have another look. It almost feels like the case back is to big, but I checked and it is the right one.
I had trouble with a ladie's oval snap back of a brand watch once. The issue was that pressing on its center distorted it enough not to fit. Once I made a wood die to press on the sides only, it went in just fine.
Sounds like my problem
You could try the lipped recess type of dye that you would use on the bezel for the case back. Near the edge but enough substance of the dye on the case back not to splay when pressure is applied.
If not I like the freezer idea
Sent from my SM-T585 using Tapatalk
I don't have Two large enough dyes to both protect the Crystal and also apply edge type pressure on the case back. The freezer method did not work(darn). I would buy another installer, more professional than my current one. Any ideas.
  • 9 months later...
SUCCESS. I visited a local watch repair shop and asked if he could get this caseback on. He said it would cost 25 bucks and I would need to leave it with him. Then he said that the case back was warped and that's why it won't go back on. I had an instant eureka moment. All I needed to do was to push out the center a bit then press it on. So i thanked him for his advise and rushed home. Put the case back in my GS press and pushed on the center a bit so it was just a bit bowled out. Flipped it around with the watch in place and it snapped on with little effort. Ta Da! As a favor to the watchmaker, I gave his son my card as a reference to his son who recently graduated from Electrical Engineering, for a potential job where I work. All good.
here is another thought:  when removing the back,  was it very tight?  (and a cheap case or a defective case)?  use a dremel  grinder on the case back lid.    JUST A LIGHT PASS !   "and try again".  vin
Got it back on as discribed
    • Hello everyone, My name is Matt and I like vintage watches along with pocket watches. I'm very new to the hobby of watchmaking, I've only been tinkering for about 2 months and I'm happy with some of the projects I've salvaged.  First I repaired This Waltham 17 jewel 18s and that was fun.  Then I repaired this old Zenith movement with 19 jewels. I couldn't find it on the pocket watch database though.  Then I repaired this one Lucerne 1 JEWEL movement. It was actually the first watch I got but it was so difficult to put back together with the fiscal amount of tools I had at the time so I just left it strewn in a Ziplock bag. Then My most recent project that came up a total win was this Longines Caliber 19AS, 17 jewels unadjusted. It turned out beautifully in my opinion and was by far the most difficult to reassemble.  I am in love with this hobby and its kind of engulfed my personality as of right now.  I plan on giving the Longines watch to my uncle, and so right now I'm trying to enjoy that watch the most I possibly can.    What I'm currently working on: A Seiko Automatic with a little date window and a weekday function too. I think its the 6309A.  Then there is this Omega pocket watch. Unfortunately I lost a little screw that held in the click spring. I'll have to source another one because its tiny and my room is filled with carpet, that thing is gone. Then theres this little tiny Elgin pocket watch. It's fully assembled but the amplitude is low and so I think it needs a new mainspring.  Then theres this Waltham 7 jewel movement that I also cleaned and reassembled, but it'll only run facing one way and again with the amplitude being low, I think it needs a new mainspring as well.  And finally, I'm working on this gorgeous Grade no.3 1883 Waltham Pocket Watch. It came with a broken balance staff on both sides and would only run when the watch was like sideways, crown to the sky. I'm really excited about that one though, might be worth something.      I've chosen to not show the other ones because they're not in movement holders right now, and the Omega is not put together.  As you can see, I take these pictures using the flash. Idk why but I like the way the flash makes the metal shine more than just my little lamp.  I'm also very eager to find a replacement for that balance wheel; any links would be appreciated.  From what I could tell on the Seiko, it's just dirty and It should run if I put it together carefully after cleaning.  Also, I fear that that 1883 Waltham may not run too good because of the mainspring, it's probably set because it's so old. I may seek a replacement for that too. I also need to find a crystal for that 18s gold filled Waltham that I've put together. It's just scary having it exposed.      I ALMOST FORGOT to mention. Is this Omega real?      You gotta turn your head a bit but it does indeed say "OMEGA", so I'm confused. I never knew they made pocket watches. And thats why I'm skeptical. Please let me know.    But thats pretty much it. I just wanted to put this out there so that I could begin using the website properly and also to let some people know I exist I guess.  Also this is my second account. I know that may violate some rules but I did the introduction wrong the first time and I wanted to fix it by making a new account. Please don't ban this one.    Thank you all, -Matt
    • Sounds like you and @VWatchie were unlucky. Mine has been running on 230V UK for years  ( it's been 230V for many years @Neverenoughwatches, not 240V).  Though I have had to re-solder some wires. When I buy cheap Chinese electrical components I often take them apart to check they're not going to kill me. Since the demagnetiser, I bought a cheap fish tank heater for my plating set up. Plugged in, big flash and smell of burning. Deader. So I bought a cheap cup heater plate. Exactly the same - flash, bang, wallop.
    • The old crystal is cracked on the edge, and I am looking for something like for like.
