I found this video on YouTube and found it informative and interesting. The watchmaker is using traditional tools and techniques to repair a watch dial.
david
I may not have any better suggestions for repairing dial feet, but...what the hell is he doing?!:pulling-hair-out:
I could forgive the method, better to have those 2 points of damage visable on the dial than the dial spinning, but he shows a breathtaking disregard and lack of care to the face of the dial at almost every point of handling it. nope nope nope. I think i need to go lye down for a while now. :D
Edited by Ishima
When watches were first made hundreds of years ago, propane, acetylene and even cross slides weren't invented yet; let alone the torch. Dead center turns were used to make staffs and pivots until live center lathes came onto the scene.
 With the exception of a motorized watchmaker lathe,this watchmaker is using, more or less, traditional tools and techniques. Obviously a dial foot soldering machine or even a torch would leave a smaller impact on the watch dial. My guess is the watchmaker in this video did not have access to these tools yet he repaired the watch with the tools he had on hand and did it in a very skillful manner.
david
If the repair is hidden then I suppose it could be a way. The interesting part for me was how he steadies the piece with the end of the tip over rest. I might try that one. If he had used a song metal glue & did not drill completely through his method would work.
If you watch some of his other videos you can see that he is highly skilled and seems to have years of experience. I would find it hard to be judgemental  toward his approach as I do not know his situation.  Many people in the eastern block countries live under extreme poverty as well as having to deal with political and infrastructure problems. It can be difficult to afford food let alone a bottle of Loctite or a tourch.  I feel that he did well with what he had to work with.
david
Hello David,
I accept totally what you say in respect of the Eastern block countries.
  Jarosław Wilczyński definitely has skills far in excess of anything I, as a tinkerer, would aspire to. I decided to look at some other videos he has put on the tube and was surprised to see that he has indeed got all the modern equipment you would need as a watch repairer and maker. Check out what he was using 4 years ago "Zarta 1800 watch consist" and some of his other videos showing timing machine, parts cleaner etc.
Without, I hope, being judgemental, I feel that he was merely demonstrating his skill in a way to perform a task, perhaps as it would need to be done if you did not have the relevant tools, and in honesty he succeeded from that point of view.  I would guess that he perhaps would not work that way normally and was just having some fun.
The idea of taking a hammer to the front of a dial especially without a fine punch certainly had a shock effect on me. However, even with the two holes he created and covered with white paint the whole demo of his skill was educational. As I said I do not have his skills and would probably have used something stupid like sticky dial pads.
In conclusion, I recommend that people should check out his video on "Omega Seamaster - Cleaning, folding, checking" if you want to see some more of his real skill, he has the most steady hands I have seen and note the attention to cleanliness and care - finger cots included. A talented guy.
Regards,
Vic
In the Seamaster video he handles the dial with a pair of steel tweezers! And the hand removing and fitting was a bit scary. Who hammers on hands?
Edited by rodabod
31 minutes ago, Geo said:
Have a look and see, 2:50 mins in.  :huh:
Good Lord, my pocket watch is smaller than that beast.
I've never tried hammering the chrono hand on before but then maybe that's why mine slip.
I wonder if it's easier to tap them on when they are new and feel a bit tight. I'd be worried about cracking a jewel or damaging a bush if the movement holder didnt support it at the rear.
Vich,
I was impressed with the watchmaker's skill and obvious experience. Apparently some of the other forum members were not. I am anxiously awaiting their videos covering the same repair procedure.
david
David, I don't think they all meant to bash the man for his technique, but only to point out that it was quite unusual. Ok that was an inexpensive Seiko 5 watch, and probably he was just showing an alternative "ancient" method to do that kind of repair, but looking at his other videos, I do sometimes see things that make me cringe sometimes. And I am not a professional watchmaker, just a hobby watch repairer... So my opinion is to be taken for what it is worth: almost nothing.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
