Different way of cleaning a clock !!!!
clockboy
Interesting for sure. I've cleaned metal parts by boiling them before, with dishwasher soap in the water, usually when there is a tough residue (paint, glue...) that needs to be removed. It's very effective and is a great way of cleaning parts with lots of nooks and crevices.
That being said, I would be weary of using it for clock or watch parts... I'd be afraid that the heat could affect the parts in some way, especially if different metals are involved (different expansion/contraction rates).
But if it works for this guy, and he has waaaaay more experience than I do, then it must be perfectly fine!
35 minutes ago, clockboy said:
Also it does not look that clean when finished.
That's what I was thinking.
Even before I got my US cleaner and just soaked parts in my clock cleaning solution they came out cleaner than that.
What a nightmare of a video. He broke nearly every rule in the book on taking a clock apart.:mad:
After removing the hands and dial, the first thing is let down all the power in the springs. He decided to remove the pallet cock and pallets first, so why didn’t the train wiz round? Very strange, unless it was the editing in the video, never the less it shows what he did and it is wrong. Removing the pins with not a care in the world (I nearly had a heart attack) great care should be taken and each part removed should be inspected for any wear. Never try to undo nuts with nippers they mark the nuts, use smooth jaw pliers or better still use the correct box spanner, which is what I would use. God knows what marks he made while trying to remove the hammer wire and the attachment, the wrestling he had was manly off camera. We could all see he did nothing with the two barrels, never looked at any of the wheels, pivots never checked for wear. The boiling of the parts, what the hell was he thinking of, there are many types of clock cleaning fluids these days with a good cleaning all parts will come up looking like new, his still looked dirty and it was a bloody eye sore. He should be kept away from any type of clock; the man is a bad advert for the trade. :pulling-hair-out::pulling-hair-out::pulling-hair-out:
Clockboy please don’t frighten me with any more like this. :D
4 minutes ago, clockboy said:
Sorry.  just shows not every vid on YouTube is showing rhe correct methods
There's some real screamers on their of idiots changing batteries using there fingers and metal tweezers. A sure sign they won't last long.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
