clock bearings
matabog
Hello!
So I cleaned the clock parts in naphta and IPA. I put the wheels in a drill machine ('cause I don't have a lathe) and I polished the pivots (they are so clean and shiny now).
How do I polish the bearings (the holes in the plates)?
I'm thinking at puting some polish compound on a toothpick in the drill machine  and presenting the bearings to it.
Bogdan
4 minutes ago, matabog said:
:) It would be so nice to be so, but there is hardened gunk in there... green stuff - best place to see it is on the mainspring barrel bottom and top holes, it didn't dissapear with naphta or IPA.
Try nitro thinner, it's aggressive to any dirt but does nothing to metal.
+1 for Horolene, an old toothbrush, rubber gloves and an open window!
If Horolene is not available in Romania, then no doubt there is a local equivalent - it is ammonia based and brings the plates up nice and shiny and is used for almost all parts altgough I never use it for springs. My recollection also is that it's not recommended for some more modern clocks with laquered plates.
Remember to ensure parts are fully submerged and wash off then dry thoroughly to prevent streaks and tide marks.
S
S
I would hope any chemicals recommended on this forum and used. The person that intends to use them would read the instructions before use.
After polishing the pivots & inspection for wear etc I put the plates in a ultra sonic cleaner. After this I then check the holes (bearings) for cleanliness using a loupe. The final check is to check for wear making sure there is not to much shake. If there is then I re-bush the offending ones & check again.
I do have a watchmakers lathe & generally make my own bushes & also use it for the polishing of the pivots.
I do have in stock bushes including some Bergeon bushes although the later I am not a fan of because I like to re-bush with no trace of it being done (if possible).  Centering is important & also inserting the bush in the correct position is also important. The bearing holes normally wear in a pear shape so this has to be taken into account when reaming the hole for the new bush.
I think oilite bushes are coated and are really bronze which for invisible bushing in a brass plate  will not do. I like clockboy always made my own and made sure they were invisible. I even had very old brass to match the old brass colour. If used correctly the reamer will find the center of the hole.  Bergeon bushes I would only use in the sort of smiths strike and chimes, cheap mantle clocks.
right you are,  clockboy !   I have a couple mvt.'s that are "bushed badly"    its  not worth the time to "re bush"  EVEN IFF"  the bushing holes holes are "in the proper place"   i just install a battery mvt. and give them away for Christmass.  vinn
1 hour ago, vinn3 said:
oilite is "oil impregnated   into bronze".  shood be  quite good,  try it
I have been retired for many years and no longer undertake any repairs of any kind. How do you know that the impregnated oil can mix with the correct clock oil and still operate under the conditions that it is meant for.
Bronze bushes can be found in high quality movements such as Longcase regulators and marine chronometers. Bronze is a lot harder then brass so it can withstand wear, in these types of movements you also find the steel is also of a very high quality so with the combination of the two you have something that can withstand wear.
wood bushings,  i had  forgot about that  lignum stuff.   propeler shaft bearings and even lathe head stock bushings.    in the  automotive area,  oilite had  replaced some roller bearings.  it could be good in old clocks since the oil  would not  harden.   vinn
  • Similar Content
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
