Rolex GMT 1675 stops , crown comes out.
Hello. I'm experiencing this new problem on my Rolex GMT 1675. The watch was serviced less than two years ago. I leave it on a watchwinder most of the time, I barely use it. Recently I noticed the watch stopped running on the winder so I unscrewed the crown to set the time and to wind it but when I pulled it to setting position it came off, without the stem. I put it back, played a bit and it locked again on the stem. Today the same thing happened. Yesterday I used the watch the whole day. This morning I found it stopped at 12.01 circa. Unscrewed the crown and same thing happened, it came off. I put it back again. I'm wondering why this behavior. I ordered a Rolex case opener so that I can look inside. Any advice on this problem anyone?
Thanks
Edited by chriz74
The stopping issue I expect will be the auto side of the movement. I have the same issue with my Rolex 3135 but have not had time to investigate however it runs great providing I remember to give it a manual wind now & again.
As Andy suggests a touch of loctite should do the trick with the stem.
I stand corrected. The spring is still there. There is spring action when unscrewing the crown. The watch is running till yesterday, I have to understand why the crown detaches from the clutch some times.
You need to carefully extract the stem to repair the clutch mech, also using a good quality pin vice, and small flat pliers, you should be able to get it sorted, you could use a tiny amount of adhesive to be sure, but don't use too much otherwise you will lose the clutch functionality.
Hi Chriz,
You mentioned that you usually have the watch on a winder. How often do you set it to wind?
My view is that if the watch is running constantly what you're doing is putting unnecessary miles on it. .. a watch is a mechanical device and like anything with moving parts...it will wear.
I could understand if it was a perpetual calendar with all the bells and whistles as these are a pain to set correctly but for most watches storage in a sealed container and a wind every few months should be sufficient.
Bear in mind Rolex autowind stuff (pivot post especially, reverser wheels not so much) need replacing every few years and original parts are getting hard to source unless you go to Rolex!
As for the crown, you may try recrimping the crown but you need to solve the underlying problem as to why it stops. A properly serviced Rolex should go for more than 2 years before it needs servicing.
Anil
Its to get a better assessment of the regulation & to check that the auto-wind is working correctly. I don,t think running a Rolex on a watch winder for a couple of days will make a lot of difference to it,s life.
The OP specifically stated the watch is on a winder most of the time, not just for checking. I agree with Anil that for most watches this is unnecessary and can be a cause of premature wear of parts. I do have a very nice walnut watch winder myself, which these days is used as a large display case, it's never switched on.
Stephen
The point is it isn't on your wrist, so why put wear on the autowind parts? In the OPs case (and mine for most of my watches, particularly the valuable ones) the watch is worn very little but the wear on these parts will be the same as if it is worn all the time. Even the best autowind parts have a limited life span because of the constant movement and associated wear.
As you say your watches will certainly outlast you (I have cheap Timex autos going strong that are as old as me, and I'm not young) but the autowind parts won't, even less so if used constantly.
I suppose it wouldn't matter if you always pay for an official service as these parts will probably be replaced automatically and are already covered in the cost. However I intend to service my own watches and would rather not have the expense, and even more so these days the trouble/difficulty, of having to replace parts unnecessarily.
These are the reasons why I have gone from using an eight watch winder and rotating all my automatic watches on in the past to not doing so now. Obviously others may choose to do things differently.
Stephen
I agree about winders, they are simply marketed towards those with too much more, and no common sense.  Would you leave your car engine running all the time its parked up in the garage? No, rest my case.
The question is: what happens if you have a watch serviced then put it in a box and never use it for let's say 10 years? Because that is what I did in the past and what happened was that these watches had to be serviced again as they all dried. The Rolex of the subject is 46 years old, I have it since 2004 and used it very little in 12 years. It's been on a winder for 2 years now. In 2004 it was serviced at Rolex and 2 years ago at an indipendent wm.
Edited by chriz74
Hi,
Sorry to have taken your post off topic. I recently came across an article on this subject that explains it better than I can, and is written by someone who knows a heck of a lot more about watches than me: http://watchguy.co.uk/should-i-leave-my-watch-on-an-autowinder-when-im-not-wearing-it/
With regards to your question you can do as Anil suggests and put the watch away (I don't, I keep mine in a cabinet) and then wind it or wear it occasionally. You could even give it a day on the winder if you prefer - if you did that one day every month or two months you would still be putting a lot less wear than doing it 24 hours a day.
Bear in mind that I am approaching this as someone happy to (try to anyway) service my own watches and if the oil really has dried up I'd much rather clean and oil again than have to replace parts.
Stephen
So, here's the thing, ther clutch chamber is coming off with the stem as SSTEEL suggested. I could lock the crown again on the clutch by rotating it a little but it will come off again if it is rotated again so I believe either the clutch part ha worn or the inside part of the crown where the clutch goes is worn and won't hold the clutch. I think I will need a new crown.
As for stopping could it be when the clutch splits from the crown the stem will be pushed inside the watch more and causing this behavior? Now I reassambled the watch, set and wound it. I put it on the winder let's see if it will stop again.
3 minutes ago, chriz74 said:
New problem: how do I unscrew the piece of the crown that stays on the stem without ruining it (the stem)? Two vices?
ideally hold the stem in a pin vice , you could remove the remains of the crown then with pliers
    • I'm currently 3D printing a new basket and trays for my Pearl machine - I printed one last week in PETG material and it worked well at first. I had taken a calibration cube and soaked it in old cleaning fluid for 8 weeks and then measured it, and there was no discernable swelling or shrinkage and the cube seemed mechanically intact. All went well after the print and then onto the drying..... that's when things went awry. The heat was more than I was expecting and the basket and individual trays warped and deformed. I am now trying to print from nylon - which is extremely difficult to print with, my third attempt is chugging away now while I am at work - hopefully I don't go home to a ball of wool like last time!
    • It is possible to true the pearl basket to run better takes a good hour of filing though.
    • Yes, the general pat is this. On my diagram the points where the springs rises and levels are marked with red circles. This is only to show on all pictures (the ones that doesn't show this points as they are seen only from aside, not from above) where this points are. On You pictures, the pont where the spring rises is not marked. The point where it levels is marked with A. The point B is where the change in radius should start, but there is sharp bend there which should not be that sharp.
    • I agree, very minimalist dial,  but then the diamond. The 1973 R has a black dial and gold case and is similar in layout. But on the MyBulova site there really is nothing else like it...
    • This is such an odd Bulova. Off of the top of my head the only other mechanical Bulova that I can think of that has the 'Bulova' logo as an hour marker is the Golden Clipper 'J' (there must be others), one of my favorite dials. And then it has a solitary diamond, which is not unusual with Bulova, but paired with the 'Bulova' hour marker, that only leaves two quarter hour markers, and I can't think of another Bulova that has only two hour markers like that. You do you Bulova, no conformity here!
