Chinese Timegraphers
As @xyzzy suggested, I just soldered a lead to SPK (GND) and R3 (tricky!) and managed to feed it 5V from my power supply.
The voltage at C1 is still about 0.3V.
I put the meter in one of the lines to read to current, which appeared zero, or close to it (I need to solder the connectors on my test leads, they are cheap rubbish, so I was getting fluctuating results).
It may never work, but at least I'm getting some enjoyment and learning something from the testing 😃
26 minutes ago, VWatchie said:
Having read some of the posts in this thread I am thinking that I refuse to become an electronics engineer to be able to repair mechanical watches. Nevertheless, I'm utterly impressed by the effort. Good luck!
I am an engineer (aero) but feel totally stupid and clueless chasing electrons around !
Could someone with knowledge please comment the finding that REGV is 0,64V on the faulty board instead of the correct 3,3V?
Is that a faulty CM108 (internal 3,3V source) or could it be an external short circuit?
Edited by Kalanag
REGV is generated by an internal 5V to 3,3V regulator.  Either, the regulator is bad, or there is a load on the regulator that is preventing it from giving a proper output.  REGV goes to a capacitor (unlikely the problem) and to a 1,5K resistor back to the usb plug.  If you have tested both boards with the same USB cable, then the USB cable is not a good suspect.  You could remove the 1,5K resistor and take the measurement again.
Here is the reference circuit of the C108. As we know, the internal 3,3V source of the chip delivers just 0,6V. If there is an external short circuit it only can be the capacitor C5 (which is C1 on the board). @mikepilk measured 0,6V at pin 3 of the USB socket which indicates that there is no short on the USB side. C1 can be tested without desoldering.
Edit: @LittleWatchShopwas faster…
Edited by Kalanag
I have not been following this thread closely...just looked at your previous post.  So, I did not have all of the other measurement data.
I doubt the capacitor is shorted.  Extremely rare.  Possibly a solder bridge, but you would likely measure something closer to 0V
4 minutes ago, LittleWatchShop said:
…I doubt the capacitor is shorted.  Extremely rare.  Possibly a solder bridge, but you would likely measure something closer to 0V
You are right! But if the capacitor is o.k. the C108 is shot 😞
Edited by Kalanag
Yes! It looks good!
You can test the capacitor with the continuity tester („beep“) of your multimeter by applying the probes to both ends of C1 and listening to a very short beep. If nothing is heard reverse the polarity of the probes and try again. The board must not be connected to the USB cable.
Another option is the capacity test function of your multimeter. It can be used without desoldering the capacitor.
Edited by Kalanag
I tried the capacitor testing with my board. Both methods work!
Method 1: The „beep“ is very short so you have to listen carefully.
Method 2: With the black probe at the grounded side and the red probe at the IC side of the capacitor the reading is 3,8 microfarad.
11 hours ago, mikepilk said:
I do have a DC power supply I bought for plating. I need to read the instructions (so I don't blow it up) but I think I can set it to 5V in "voltage mode", then see what current it draws. Or do I need to put the meter in-line?
Set the voltage knobs to 5 V, and the current knobs to something like 0.500 A.  The output will be limited to smaller of the two.  If there is a short or near short, the C.C. light will be on and the power supply will limit to 0.5 A.  The voltage will drop to whatever it needs to be to keep the current below 0.5A.  What should happen is the C.V. light will light up, the voltage will be limited to 5V, and the current side will tell you how much current it is drawing.  You don't need to use your meter, but that power supply will just give you two digits while a meter might give you 3 or 4.
10 hours ago, Kalanag said:
The results (just) on the USB side of the board are very different! The REGV output of the CM108 has the correct voltage of 3,3V where the faulty board just has 0,64V.
Thanks for posting that.  I am glad to see on a working board everything is just as I said it would be and the things I called out on the working board as wrong, are in fact wrong.
If the current powering the board is reading new zero, one might think it can't be a short, but that might not be the case.  The CM108 regulator might automatically shut down if shorted.
Possible shorts in REGV are C1 (C5 in the C108 example schematic), C12 (C4 in the schematic), and the USB connector itself.  As well as the pins of the CM108 next to REGV.  I don't see any solder bridges in the photo of the pins.  The connector could be shorted, but we'd except to see a voltage drop across R2 (R3 in schematic) and there isn't one.
Another thing to consider is the mic bias voltage.  This is also sourced from the C108 and is also wrong.  I don't know how much current the C108 can source on this pin.  Depopulating R6 would stop it.  It's connected to R6, C15, R7, and C16.  And then it goes to the amplifier section of the PCB.
VREF, right side C9, is also wrong.  It's 0.12 V and should be 2.25 V.  I don't know what would make that wrong if the chip is getting power.  Too much power draw I assume could do it.
Argggghhhhhhhh !   There was an old lady who swallowed a fly .........
After messing around with my power supply I couldn't get the current set - it's broken too. So ignore the results I posted yesterday, I don't think it was supplying any power.
I hope to have it fixed* soon, and my new multimeter with (capacitor testing) is due any day.
(*If I haven't bored you too death - I Googled the model and found it's a common fault - seems that the P75N75 MOSFETs blow 🤪. So a quick course in diagnosing blown MOSFETs. With the meter set to Diode mode, I did a diode check: the NMOS test D-S, all 4 read about 0.41V, but then reversing the leads, two of them read about 0.41V, but two went off scale, I assume they are broken?
I can get them quite cheaply on ebay, so will try to replace them.
45 minutes ago, LittleWatchShop said:
Are you talking about components on your power supply?  The measurements you show are not testing the mosfet.  It is testing the protection diode.
The article does say MOSFET testing, and starts with the diodes. I assume they are part of the MOSFET? Looks like 2 of mine have failed.
https://electronicsbeliever.com/how-to-know-if-mosfet-is-defective/
Edited by mikepilk
Well, those tests do not test the mosfet.  They test the diode (both intrinsic and protection).  They test a gate-source shunt resistor which, frankly, may or may not be there.
No effective way to really test a mosfet with a single DVM.  Well...if the D-S were shorted or open, a DVM would detect that.
Edited by LittleWatchShop
But if the diode tests fail, doesn't it mean my MOSFETs are toast ?
Yes, that is correct.  I edited my response to say that a short would be detected, or an open circuit as well. There are other failure modes for mosfets that would not be detected.
I dont know what you mean: "two of them" did this and "two of them" did that.  Are you saying that regardless of polarity, two of them read 0.41 V?
I thought they did, but now with the NMOS test shown above, Red to  S, black to D, all 4 read 5-5.2V. With the leads reversed, I don't get a reading for any of them now.
Sorry, I need to do some more reading and stop wasting your time. I did the above in a rush before some proper research.
Keep in mind that the displays on the power supply have two modes.  One shows the max values you are setting, the other shows the actual values as it supplies power.  You can't get both current and voltage to be specific values, it would violate Ohm's law.  You get one, then the other is forced based on the resistance of the load.  You set maximums for both, but only one max, V or I, will be reached and the other will be whatever V = I * R produces based on the load's R.
So maybe the power supply needs to have its outputs off to show the set points?  Most seem to let you adjust while on, and the digits will flash to let you know you are in set mode rather than measured mode.
If the power supply isn't connected, it should read 0 A when on.  How can it supply current when there is no circuit?
  • Similar Content
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
