Locked escape wheel.
Working on a Vostok 2414, I fitted a new escape  wheel and pallet fork. When I activate the balance wheel, the escape wheel moves but does not advance. In the picture, the position of the pallet pin is with the fork as far as it will go against the banking. If I filed a small amount off the solid banking, I think it would solve the problem. Is this permissible practice, and has anyone encountered this before. I don't think the watch is far enough out of beat to cause this, also the same thing happens when tested with some wind on the mainspring before the balance is fitted; the escape wheel will not advance. I hope the pictures are clear enough. Thanks.
Frank.
Edited by fjseal
Add another picture.
Is the pallet fork installed right side up ? Usually the pallet jewel on the longer arm is to the left . Is the impulse jewel on the balance between the fork fingers ? With out the balance installed you should be able to tickle one of the gears to see the escape wheel and pallet fork engage and move the pallet fork left and right . I don't think that I would file the the solid banking to solve the issue .
Not knowing a whole lot about watches; but I can't see the guard-pin (#4) on your pictures? To my humble mind this one should be visible from the side the picture is taken from. Unless the 2414 pallet hasn't got a guard pin or the pallet is the wrong way around like ricardopalamino suggested??
Picture just for illustration of the parts / names, I know it's not Swiss ;)
Thank you for your replies; Endeavor,  the guard pin is there. On another website there is a walkthrough of this movement, and the pin is facing down. Because of the different length of the pallet fork pivots I think it is impossible to fit it the wrong way up. The other thought that ocurred to me was that the pallet pin may be set too far out. Incidentally, the new fork came with a new escape wheel.
Ricardo, the escape wheel does not advance even without the balance fitted, and tested as you suggest.
29 minutes ago, Cad101 said:
Have you tried it with the new escape wheel provided with the new fork.
OP said: "I fitted a new escape wheel and pallet fork". Seems like one of these is faulty.
Sounds like you haven't got the balance wheel in the right position? Loosening the bridge screw and rotate the wheel until it engage with the pallet fork. The jewels hits the outside of the fork instead of sitting inside it. Happens once in a while for me at least.
But as the OP mentioned above, the escape wheel does not advance even with balance removed and the tip is moved manually. That is a fundamental test.
Ooops. Then there must be some other problem?  Remove the pallet fork and work his way backwards.
It's very easy to put in a pallet lever upside down thus making it impossible for it to interact with the escape wheel properly.
Don't ask me how I know this.
Dave
Not sure about Russian movements, but it's impossible with the Si
What ever you do don't touch the banking pins because if you do you will end up with all sorts of trouble.  The first thing I would do is release all the power, remove the pallets, put a little power on and see if the train is free, make sure all the train  has good endshake, inspect the pallets make sure the pallet stones are are set firm and pallet jewels are ok, put pallets in making sure the pallet bridge is fixed, add a little power and make sure the pallets are free up and down and have good endshake, now touch the pallets with your tweezers and see if the escape wheel will escape. Try that first and let me know.
9 hours ago, jdm said:
Sorry. With Seiko.
Ah, so no silicon then? Was wondering...
I know nought about Russian watches except that a woman I met who was from Russia had been saving for a car and because of the devaluation of the Rouble she was only able to buy a Russian-made watch.
Update:
Thanks for your advice oldhippy. I have followed your procedure...I am happy that the wheel train is functioning perfectly, no binding of obstruction. It's almost as if the escape pallet pin is set a little too far out of the pallet fork. The mainspring is new, but the fork does not 'flick' confidently like you would expect it to. I will attach a photo of the new  pallet fork so you can judge if it looks normal to you. How much 'endshake' should the pallets have?
i might suggest putting one or the other of the old parts back in and try it. try the new pallet with the old escape wheel and vise versa. is would seem that one or the other of the new parts is faulty. i know that is a stretch, but it can't hurt to try it.
Edited by ramrod
To me that pallet stone is set wrong, trying to line it up it looks to me to be out of line. I cant find any info on pallet end shake So touching the pallets when set into the movement the pallets wont escape, have you tried a little oil on the pallet stones, then oil the balance pivots and fit not forgetting the shim that goes under the balance cock and screw tight making sure the balance staff is set in the jewels.
Here are two pictures I have found with pallets fitted and the pallets stones can be seen clearly that stone is not set in the same position as yours, there for I think yours is at fault and that is the problem. Sorry if you think I've gone all over the place with this but this is something you might come across and is good practice in fault finding.
Easy to do!
I am in watch heaven; I got 5 junkers from my watchmaker friend!! Some good names too, Seiko, Lorus, Caravelle, etc...
I just de-cased the Seiko; something I'd never been able to do w/out one of Mark's videos on the subject.
Back to the bench...
Dave
    • A couple of pictures of the front… Sorry, I’m months away from this one…good luck…
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
