Some Bits
BeyondWorld
Atomic.
And on the back in french it says something like "though land, though sea, through the sky, to the moon!" on the back, which I think is kind of funny.
Probably my favourite watch to wear. It's a hard choice between the speedmaster and this one for me. Although I think everyone would probably go for the speedmaster.
post-1618-0-86204500-1454860256_thumb.pn
Hi B,
How big are they? Is the Cyma model still available somewhere?
Cheers,
Bob
Mine is 41 mm with the crown. 38 mm without.
They are around in England, and ebay, as being british military watches. They are from the 1940's so, I'm guessing you mean they are available second hand, and not like somewhere new in a shop. :-p
Wow. It's getting better and better the further down i go. Love the Lemania and the Eterna. And the Speedmaster with it's JB champion strap is wonderful. Looks like a 105.012 with the DON bezel or  maybe a 2998?  Congratulations you have a wonderful watch collection.
Thanks for sharing a very admirable sampling! I'm head over heels for the Eterna Telemetre. Do you have any additional information about it? I'd love to add that to my dream team search list.
Not much really, it's 1950's valjoux 22, oversized screwback, the case doesn't have any reference numbers. Apart from the case back saying it's anti-magnetic and waterproof. I've had the exact same watch in white dial though as well, so they are around.
Thanks,
Its a ST 105.013.
I don't know what DON bezel means haha, I'm not so good with the new terminology. But I'm pretty sure it's the original one.
DON means dot over ninety . The little dot that is next to the 90 . The later speedmasters have the dot next to the 90 . Like this?
DON bezel.
Dot next to 90
When Omega serviced the speedys they often changed the bezel. This makes the DON bezels worth a lot of money this days.
attachicon.gifDON ..jpgDON means dot over ninety . The little dot that is next to the 90 . The later speedmasters have the dot next to the 90 . Like this?
DON bezel.
Dot next to 90
Ah, gotcha. Yeah, I understand there's a difference between a service bezel and the original, never knew they called it a dot over ninety, interesting to know.
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
