No Daniel, there is no schedule, you take them when you can and as long as you can. Just visit the free sample lesson and you will understand what I mean. If you are spending that kind of money in tools and what not, might as well get the class I think. It is still a very personal decision though and I'm not associated to them in any way but I have learned a lot from them.
I've cleaned quite balances ultrasonically over the years without any problem. If in doubt, try it on an old movement first to see how you get on. The only thing I will not ultrasonically clean I'd the dial. I tried it early on and it destroyed the finish.
Edited by Geo
Mark re-attaches the balance to the plate prior to cleaning in his videos, and the manually cleans the jewels after. Whipping around a liquid bath seems more violent and sitting stationary in an ultrasonic cleaner so I'd assume it's safe.
Mmmmmmm, sloshing about may be Ok, I'm concerned that 22Mhz may mess with the hair spring..............
I have been collecting the tiny little Wilkin and Sons jam jars you get in some cafés, I can fit 3 in my ultrasonic cleaner and it means I can have a different fluid in each one if I wish.
The brass fine mesh balls are useful sometimes as well for the really small bits.
Like Bob and George I clean just about everything bar the dial and pointers.  The only thing I would say is dont use any solvent cleaner type substance that could dissolve the shellac/glue holding the jewels in place.
Since seeing Mark do it, I have started putting the balance back on the plate and it seems to be perfectly ok that way, it does not take long plus the plate gets a clean as well.
Cheers,
Vic
As title really, all of the sites I normally use for my watchmaking, Cousinsuk, HSWalsh, and Gleave & Co, are all based in the UK, and all cannot ship the products I need to Finland due to being dangerous chemicals.
I am preparing my Elma Super Elite, watch parts cleaner machine, and need these following products...
L&R 111 Cleaning Solution
L&R #3 Rinsing Solution
15508778617_5ff71f4ba5.jpg2014-11-02_2210 by Micky.!, on Flickr
So as you can see, I am a little stuck on where to buy the above products from, and I don't know of anywhere in Finland that would possible sell them :(
Edited by SSTEEL
Hi Micky,
Have you tried some US suppliers? Is it the same situation as with UK?
This is unbelievable but I searched for "watchmakers supplies, Finland" and I got "Rio Grande" suppliers... not even supplying watch related products. Apparently Mexico has borders with your country!! :D
In any case, if you don't find one close to home, check our directory of suppliers, maybe there is one close enough that can send what you need, probably ground shipping. I believe it is going to be expensive at best. If you were to find one in Finland, tell Mark so he can add it to our directory.
Bob
Ouch, that is a bit pricey.
As this is a hobby with me I'm going to experiment with brewing my own. I picked up an old watch cleaning machine recently and l love to experiment. I will post how I get on whether good or bad.
I clean all my balances in the ultrasonic and have had no problems, however I have learnt to be a bit more careful with the Pallets as the cleaning solution can get a bit warm if used for an extended time period ( I personally can use it quite a lot in a one session) and sometimes Pallet jewels can come loose due to the shellac/ adhesive softening because of the increase in temperature within the cleaning solution...
Cleaned a watch this afternoon using my L&R machine and noticed the parts are a little bit sticky.  Thought it was my tweezes but i think the movement parts have a film of some sort on them. I have recently cleaned several clock parts in the L&R & wondering if there was just too much old oil etc & it has contaminated my cleaning solution.
I have been keeping count using two counts for clock movements & it totals 18 washes. Any suggestions guys.
I have been using Elma
I would not normally do clocks but if I did then I would use a separate jar of cleaner for the clock parts.
I used to work in a place where the clockies would take our used watch fluid to clean their watch parts (too dirty for us but clean enough for them). The exception was platform escapements which would not normally be a problem in the watch jar.
I have never used the Elma fluid but I have almost run out of my current stuff and was thinking of giving the Elma fluid a try. Apparently you use distilled water in the first rinse. Right now I use L&R watch rinse in the second and third jars. When the second jar gets dirty I will swap the third jar in it's place, discard the second jar's fluid and refresh it with new fluid - it becomes my new final rinse. Less waste this way.
    • H Watch Repairers—is there is a ‘standard format’ for the service marks or codes lightly engraved inside cases of pocket watches or wristwatches?   Sometimes I can see there might be a reference to year/ month but other times am confused. I’ve included an image of the rear of a 1951 Hamilton 992B Railroad pocket watch as an example. Thank you for all information you can give, Mike
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
