2824 Keyless Works
ahabec
Hello all.
I want to build a 2824 watch for myself and trying to avoid a clone, I bought a 2824-2 from an eBay seller in -- of all places -- Cairo, Egypt.
I have one watch with a Chinese 2824 and really it's a fine movement, but I detest the shamrock-like spring the low grade ETAs and all China movements use for shock protection. I think it's called Novodiac.
Unlike the spring used by Seiko, which is really easy to fit, the Novodiac seating has 3 openings, making the purchasing of a tool almost mandatory (very smooth move there, Bergeon). I did not buy it so setting the Novodiac is a pain in the euphemism.
ANYWAY, the movement sold to me from Egypt seems legit, it has the ETA logo and older type incabloc spring.
But the keyless works is of an older type, it has a spring for the setting lever which is separate from the bridge. The stem releasing part is also designed differently.
It is giving me some issues where winding and setting the date is fine, but when pulling to set time one needs to really pull hard on the stem, otherwise it goes to some middle position between date-setting and time-setting and the wheels don't engage.
I was wondering if anyone can help me date this movement based on the older type keyless mechanism. Weird to me that it still says 2824-2. Maybe it is fake after all.
By the way the hairspring regulation system is the new type, Etachron it's called I think.
Seems keyless works has been annoying in all iterations of this movement. It really is its weakest point.
Thanks!
Re the novodiac.
You can make your own tool out of plywood.
1. Get the outside diameter the same size as the inner part of the jewel setting.
2. Make a divot in the end.
3. To use..get one leg in the groove, another in the opening [one more leg will be on top of the edge]. Put your tool on top of the nobodies spring and turn.
Works for Seiko too!
Anil
Is there a different stem? I think some of the stems for the older model are twisted. Newer models are straight . Could that be some of the problem? Wrong stem? You need a helicodial stem ?
Edited by rogart63
It be nice to see pictures of both the front and back side your movement. Plus a close-up of the balance assembly with the Etachron and the incabloc spring.  The reason for the close-up of the balance assembly is if it's made in China they don't always look exactly the same as the original. The Chinese do clone the incabloc lthough the usually skip a step or two in manufacturing.
Then this watch came in a variety of variations and the parts are different at least between the original 2824 and the rest of them. I've attached the PDF parts list for the original 2824.
ETA 2824     28800 BPH-DSS-AUTO-CALD W/CORR-STOP SEC
ETA 2824-1     28,800 BPH-DSS-AUTO-CAL W/CORR-STOP SEC
ETA 2824-2     28,800 BPH-AUTO-CALD-DSS
ETA 2824-A2     MECH MVT W/HEU 81 CHRON TOP MODULE:
ETA 2824R     28800 BPH-DSS-AUTO-CALD W/CORR-STOP SEC.
1388_Eta 2801,4,6 Part1.pdf
1389_Eta 2801,4,6 Part2.pdf
  • 1 year later...
You have a 2824 or 2824-1.  The -2 has many improvements including a 1 piece spring and set bridge. (that goes on top of the keyless works).  The -0 and -1 have separate spring.  On the -2 its part 445 (eta part #).  Its used in several different eta movements.
Ironically I need parts from that movement you have.  If you want to sell it or trade it for a -2 let me know.  Thanks
You mean trade the complete movement that I have for a complete movement from you or just the keyless spring and bridge?
  • 11 months later...
Personally I think the Seagull ST2130 is an excellent copy of the ETA 2824.2. But the keyless works is a pain and stems that wont stay in are a common problem. The secret is to tweak the part shown above so that tab on the Combined Setting Lever Jumper (445) that presses down on the setting lever has a slightly higher tension and a dab of grease where the setting lever pushes against the Yoke when entering time setting mode. You may also find the part of 445 that clicks against the pin on the setting lever either needs a dab of grease or reducing the tension (which can be done with a screwdriver while its all together). If you don't do this, when trying to get into the time setting mode, the setting lever rides up over the yoke and the stem pops out and usually wont recover.
I have just fixed 2 of these and by adjusting those 2 tensions (and greasing the setting lever and clutch) , the keyless works is a joy to use!
By the way, you can buy a new ETA 2824.2 from Cousins UK and they aren't that expensive if you buy them LP (loose pack).
  • 4 weeks later...
Indeed it does. My video.
    • I would use some binding wire around the part before heating it. It protects the steel from being burned. I know that sounds strange, as you're going to heat it with a blowtorch, but if a part is thin and delicate the steel can literally burn away before your eyes, which isn't funny if you've put hours into the job. I bought some tools steel from Cousins a few years ago which turned out not to be tool steel, because it couldn't be hardened or tempered. I wasn't impressed, as I had spent two hours making the part for it to be useless.
    • Hi that’s what was meant by animal glue “ a glue made from animal products”. Ie bone , skin and other animal residues.  There was a place at Huntington YORK who used to boil down the ingredients. It stunk.   We used it in pellet form in a sort of Bain Marie on a gas ring  it was very good, didn’t think it was around any more with the modern glues,
    • It's back to the drawing board I'm afraid. As pointed out, the Rodico trick is so fiddly and my pin vice jaws don't close in union. I tried but the screw is so small it's hard to grip the screw in the Rodico without it moving all over the place while trying to get it in the vice. I started to shake too much so gave up before the screw flew off somewhere never to be found again.  I'm now thinking that maybe I could bond the screw on the end of a bit of peg wood and then dissolve the adhesive afterward.  I just had another thought🤔 I have some really small PCB drill bits maybe I could drill a small hole in peg wood and push the screw in, as stated I only need to get the screw started.  Another idea 🤣 Magnetize the screwdriver to hold the screw 🤔
    • Yeah there is a spring under there. Hopefully now I can source a screw for the click and the bridges! Thanks for your help!
    • Definitely worthwhile, if you are working with old watches - just be sure it's an actual Geiger counter, not one of the vast range of scam/fake "Radiation detectors" on ebay & amazon etc. that detect RF or static electricity...   In the mean time, I'd put the dial and hands in zip bags & wipe down the work area with a damp cloth to pick up any dust, then discard the cloth. The emitted radiation from radium lume is not normally harmful - but inhaling or ingesting a single particle of the material can cause serious long term harm, so do take care with it.
