National Electric Watch Cleaning Machine
Why Zenith rinse and not L & R rinse. I'd never heard of Zenith rinse so I had a good look over the internet and most people say the L & R gives them better results. I always used L & R .
Zenith was all my Brisbane supplier had in stock at the time I needed it. It seems to work OK but I haven't had the chance to compare it to L&R. Both are US made products. See http://www.zenithsolutions.net/
Keep an eye on the smoke issue my L&R caught alight & thats why I had it re-wired etc. Also i have used Elma & L&R the results seemed the same just the L&R seemed give off fewer fumes.
Noted, I think I'l get a little CO2 extinguisher to hang beside my fire blanket.
Hi
Nice machine! Any particular reason why you are doing two jars of clean and one rinse? As far as I am aware it is usually the other way round.
Stephen
Doh! to quote Homer Simpson. I had it in my head that two cleans and one rinse was required, then I read my instruction leaflet. I have rectified the situation so it now stands at 1 x jar of L&R Cleaner, 2 x jars Zenith rinse.
Ditto^^  I am many others have two separate rinses.
See previous confession ;)
Thanks for all of the advice gents, I'll post up some results from my next job (a Seiko 6309A).
Now that the jars are filled with the right stuff, I turned my attention to the jar seals.
When I got them there were one and some bits cork gaskets, and as they help prevent evaporation of liquid more expensive than petrol, I decided to make some new ones.
I got a sheet of nitrile bonded cork gasket material from the car parts place, measured everything up and started.
Not having a CNC controlled laser machine, I used an old cutter left over from installing some downlights. The blade was sharpened, set to the correct radius and off we went.
The results are rather pleasing and now all three jars will prevent the angels getting their share of my cleaning fluids.
post-1141-0-17351500-1436243279_thumb.jp
post-1141-0-56374600-1436243348_thumb.jp
  • Like 5
  • 1 year later...
Hello all,
I recently bought a decent vintage National Watch Cleaning Machine on Ebay. The motor works beautifully, the heater was working, but the wiring was awful so I decided to rewire. (pictures attached)
On taking the machine apart, I found that the heating element was damaged. The ceramic holder is cracked in half and I don't like the look of the weakened filament. Does anyone know if I am likely to find a replacement, whether there is an alternative I could use as a heating element or if there is some way of making such a thing? Any advice, opinion or help would be very gratefully received.
Many thanks
Nick
Hi,
I have an almost identical machine and it had pretty much the same problem. Others will have different opinions I guess, but my thinking was to get rid of the exposed element which I did not like and utilise something else. I would suggest that as these machines use mains power, unless you are sure of what you are doing, get qualified assistance.
What I did was to utilse a 100 watt halogen globe and socket. In Australia I was able to access 240 volt versions together with the appropriate socket. Once installed plenty of drying heat was available and the low height of the globe permitted a good gap between it and the basket.
Good luck
6 hours ago, Hamish said:
Hi,
Good luck
Thanks Hamish. That is a great idea. Did you use a reflector bulb? If so did you mount it facing up towards the heater or was lying on its side. I am wondering about clearance between the bulb and  the heater? Is it the type in the picture here? This one is 75w. 100w doesn't seem to be available here.
thanks again really helpful.
Hi the one I used was not like that. See photos it is much smaller and still of high wattage (heat). The globe just unplugs but I have not had to replace it as yet. As I said this will involve rewiring so be careful. IMG_2151.thumb.JPG.0c6afd3592e25b73e1707IMG_2149.thumb.JPG.ba0f46f6311efe2121798
Just a thought, Araldite AW 106 would fix that ceramic base (good up to about 180C) and a new element could be constructed perhaps using insulated or probably non insulated (but with shielding in place) nichrome wire combined with a variable control, it's a bit more of a fiddle though.  Some people also cannibalise a cheap variable heat control soldering iron and use that as a heat source which means it is a straight forward plug in job once the element is fixed into place.
Cheers,
Vic
Cheers,
Vic
Thanks Vic,
I decided to go with a generic heating element, 110W. It takes a little while to heat up, but seems ok. I was worried of going higher in wattage, because nowhere does it say what the circuit can take, so decided to play safe.
I also added a ceramic block for safety.
Thanks again to all for their ideas. Loved Hamish's light bulb concept, but no one here in the UK I have asked has seen these bulbs.
Machine is re wired and works great now.
Dear all,
I have recently refurbished a vintage National Electric Watch Cleaning Machine. Working great. However, although I have the main basket, does anyone know if there are inner compartment baskets available for these?
I don't like the thought of putting all the watch parts in the main basket and have them whacking around.
any thoughts? Thanks
You don't say what modal it is but I have seen National baskets on ebay, it consists of 1 main basket a small cover with small indentations for train, screws and other small parts then the top cover which is flat. In ebay type in watch cleaning machine that will cover all things to do with Cleaning Machines for watches.
I have a national electric model mark 6, I purchased a complete basket of ebay to use with the one I already had on the machine it was listed as having come from a elma machine.
http://www.ebay.co.uk/itm/Bergeon-Watchmaker-Machine-Elma-basket-/172422592431?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=KLgcBrOFSBeSKrUBFNcu39dPkLs%3D&orig_cvip=true&rt=nc
I dont want to over complicate matters but this is what I found, the inner parts of the basket I bought will fit into my old basket snuggly and create new compartments the cover on the basket I bought fit my old basket, and obviously the small holding basket will fit in the compartments. The basket frame I bought will not fit the bayonet fitting on my machine as it is not wide enough, but the lot I bought came with a shaft fitted so the complete basket assembly can be removed from the machine  motor by undoing one screw and the one I bought can then be fitted to the machine again held by a screw on the shaft.
I think the main diffrence between machines is the widths of baskets and the bayonet fittings on the basket frames, the elma type are narrower but if you can find a set cheap on ebay they should still be useful to you.
Edited by wls1971
Thanks so much. I hadn't thought of replacing the whole thing. I notice that the National basket has an inner diameter of 54mm (from memory) which is smaller than the more modern Elmas.  Your idea is excellent and I'll keep my eyes peeled.
I have attached a picture of my machine for reference.
Thanks again
  • 2 months later...
I hope you're all well!
I have just picked up a National Electric Watch Cleaning Machine, all works fine apart from the heating element. I have a new one to put in. I will also be stripping cleaning and re painting the machine.
My question is does anybody know where I can get some more baskets that will fit this machine? It only came with one small basket.
Please put a picture up of basket and holder you have ... it's a little hard to imagine how the one you are looking for should look like!!
You have a number of options open to you, try and find a National electric complete basket off the bay but I think you would have more luck finding a bag of rocking horse poo than that. The national uses a three prong bayonet fitting that is 80mm across, the basket fits to a shaft with bayonet fitting  that is connected directly to the motor.InkedIMG_2500_LI.thumb.jpg.b0879c8b97b3e820dab72ca12b32cc5c.jpg
The photo above shows a National basket compared to probably the most common type of basket which is a Elma basket these are approx 70mm across, the dividers from the elma will fit snugley into the national basket so divisions can be created in the basket using these, I can with my national basket create 3 useful layers using elma dividers.
The Elma bayonet fitting is not wide enough at 70mm to fit directly to a national machine, but you can remove the shaft and fitting from the national by loosening the grub screw that hold the shaft to the motor and replace it with a Elma shaft and fitting again held in place with a grub screw, this would allow you to use elma baskets and dividers on the National machine,
you can also buy useful little baskets that will fit in your National such as these,
http://www.ebay.co.uk/itm/16mm-Brass-basket-parts-holder-ultrasonic-cleaning-mesh-screw-type-watch-tool-/301581103372?hash=item4637a2710c:g:hpcAAOSwhQhYxwhS
Complete baskets and dividers can be bought for elma type machines new such as this,
http://www.ebay.co.uk/itm/Watch-cleaning-machine-janta-pearl-brand-spare-parts-bottles-and-baskets-/291879006669?var=&hash=item43f55831cd:m:mp1w4YBMDAelzeQs1e3Twkg
I am of course providing this information assuming that your National machine has the original basket and shaft fitted, so a photo would be useful of your machine to confirm,
you will have to at any rate to keep your eyes peeled on the bay but with a little adaption your options are open in order to have a useful machine.
Edited by wls1971
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
