Folks,
I just purchased a Vari-Matic in perfect operating condition.  The numbers 12 29 67 are stamped into the hydraulic reservoir/aluminum base so I suppose it was made on 29 Dec 1967.
Does anybody know how to increase the spin-off time between stations?  I've found a couple YouTube videos from 2016 and 2011 but I can't reach those folks.  Can you please offer any advice or point me in the right direction?  I'd really like to make this modification but my electronics knowledge and skills are near zero.
Thanks!! Woody.
You can't, the time is fixed because the indexing motor runs a certain speed and it runs constantly until the basket drops into the next jar.
You should concentrate instead on making sure the spin-off speed is as high as possible without causing the fluid in the jar to swirl around and splash up and out.  All the speeds are controlled together with the rheostat you can set with a screwdriver.  But the proportions of the speeds to one another are controlled by the taps on the wirewound resistor that you can move.  I forget the exact details ... do you have the manual?  It's all spelled out.
My machine was wired wrong when I got it, giving a spinoff speed that was slower than the drying speed.  The spinoff was useless and the drying would wake the dead.  The spinoff is supposed to be faster than the dry, and it works great with that fixed.  I have been using it for 15 years now...?  Probably ran it six times today.
Sorry, "You can't" might be a little strong.  If you give up on using the electro-mechanical timing and synchronizing system built into the machine out of simple cams and switches, and replace all that with a computer of some kind, you can of course make it do whatever you want.  In my opinion that's unnecessary, and unnecessary computers should be avoided in things that I need to rely on for a long time.
Thanks, Chris, for the quick reply!  I sincerely appreciate your help!!  At 6 times/day for 15 years, you really know this machine ?.
Yes, I have the original manual.  I'll review it and the information you provided and take your advice.  I might have a followup question or 2 ...
One more question now: Do you use L&R #3 for your rinses? My big concern is fire.  My heating element gets very hot (but NOT red hot).  I'm worried the #3 rinse might ignite if droplets land on the hot heating element.  That's why I'm so concerned about spin-off before moving over to the heater.
Thanks again!!!!
Woody
My rinse's jug just says L&R Ultrasonic Watch Rinsing Solution.  An older one waiting for disposal does say #3 though, I don't know what the difference is.  I use the ammoniated #111 cleaner.
After the dry cycle, the basket on mine is too hot to touch for a few minutes.  I doubt there is any appreciable risk of fire if you are using the solutions meant for the machine.  I think we would have heard about it?
I will be interested to hear if you determine yours is also wired wrong (or what I call wrong, anyway?) in the way that gives a faster dry and slower spinoff.
Oh, does your fan run when the heater is on?  It should.
Thanks again, Chris!!
I read through the manual as you suggested and learned quite a bit (go figure!!).
To answer your questions:
1) Yes, my dryer fan runs perfectly.
2) I don't have a way to measure the basket rotational speed, but the spin-off speed seems to be faster than the drying speed .... or about the same.
The manual specifically lists L&R Extra Fine Watch Cleaning Solution and L&R #3 Watch Rinsing Solution as the recommended solutions.  I'll have to research the difference between the Extra Fine Watch Cleaning Solution and #111 but since you use #111, that's what I'll use, too.  It seems I have no worries about the #3 catching fire during drying.
How high do you fill your jars?  The manual says, "to the middle of the L&R on the jar".
When you clean watch parts, do you use the "Watch Basket" (smaller one) or the "Clock Basket" (larger one)?
If I'm reading the manual correctly, I should set the rheostat with the Clock Basket installed and the High-Low switch on High.  Then, set the adjustable resistor slider (Purple Wire) with the Watch Basket installed and the High-Low switch on Low.  Finally, set the drying speed with the other adjustable resistor slider (Orange Wire).
I think I'll do all my experimentation and adjustments with isopropyl alcohol.  That's a lot cheaper than the L&R solutions.
Thanks again for helping and sharing your experience.  I really appreciate it!!  Woody
I really only use the small baskets, I have three of them so I can fill one while another is running.  Often I use two baskets for the same watch, it takes two or more runs to clean everything, especially a chronograph or an 18s pocket watch where not everything will fit in there at once.
I have the ultrasonic unit so the jars have to be filled up above the L&R letters, and with the ultrasonic the fill level is very critical.  The fluid should be up the ultrasonic head about a cm when it's running.
If you are not using the ultrasonic I'd say fill them enough that the basket stays immersed when cleaning but is free of the fluid during spinoff.  It's not critical and you won't hurt anything if it's wrong.
I'm not so sure about using a bunch of alcohol...  that's really flammable and burns invisible, scary.  You can just run it with the jars empty for testing (but of course TURN OFF the ultrasonic if you have it).
Heck if you're just wanting to set your speeds and test spinoff etc, wouldn't water in the jars work fine?
I'm glad you only use the small baskets - the large one is almost impossible to remove!
I don't have the ultrasonic base, unfortunately.  But, I'm on the lookout for one.  Hopefully I'll find one!
Thanks for the concern and warning regarding my use of alcohol for testing.  I put it only in jar #1.  Jars #2 and #3 are completely empty so the basket is nearly dry by the time it gets to the heater.  I would have used water but I was concerned something might rust - I guess everything that gets wet is made of stainless steel.  The manual states, "The machine is used at High Speed when using the Clock Basket in order to compensate for the heavier load.  Actually, the basket will rotate at the same speed as in Low when using the Watch Basket.".  So, I used the alcohol for the viscous Drag on the basket.
Thanks again!!!! Woody
A little update on the lids I had printed in PLA:
Ammonia vapors from L&R #111 pass through the printed lids with very little resistance.  The vapors don't seem to affect the print's structural properties, fortunately.
I reduced the vapors to nearly zero with 2 payers of clear plastic circles cut from a heavy plastic bag.  I sandwiched the plastic circles between the lid and the silicone Mason jar gaskets.  Doing it this way, the plastic circles stay in place when I remove the lids to run my machine.
If you're unfamiliar with L&R #111, it contains ammonia with very strong vapors (I recommend eye protection and gloves, at a minimum).  The L&R #3 rinse doesn't contain ammonia but it does have an odor.
On 3/16/2021 at 9:53 AM, LittleWatchShop said:
Are you printing at 100% fill?
I sent the STL file to my local makerplace for printing.  So, I'll have to get back to you with an answer.
FWIW, the print resolution seems to be very high (to me, anyway .... a complete noob to the 3D printing world).  Regardless of the resolution, I guess there will be porosity of some non-zero magnitude, right?  The lid top thickness is 2.22mm, BTW.
What is the proper part distribution in the top basket?
There are four compartments.  So far, I dedicate the smallest compartment for the escape wheel and pallet fork.  If the train wheels fit, they go in the next larger basket...otherwise, the next larger one.
At present, I do not put the balance wheel or balance cock in the basket, but I am probably wrong about that...just being cautious.
The small plates go in the largest compartment.  The large plates go below.
Thoughts?
Whilst on the cleaning of hairsprings I noticed while browsing that Bergeron have replaced one dip with this. Interesting as it claims to help remove old oils which can be an issue with the vintage watches with fixed cap jewels.  I will give it a try.
  • jdm pinned this topic
9 hours ago, LittleWatchShop said:
L&R basket sets at an angle and is unstable
Ah, you mean when it's not on top of the basket.  I like it.
I too have printed some lids for my jars.  I've been testing them with IPA for 2 weeks now and seen very little evaporation, this is at 25% infill.  But I like the idea of using a plastic circle (with the gasket) to be doubly sure.  Thanks.
Related to L&R machines.  I'm in the UK so parts are hard to find for these American machines.  I'm looking for the tray insert that has 4 or 5 compartments, if anyone could help me out.  Ebay has them occasionally but the shipping to the UK is extortionate.
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
