I  removed the timer assembly and found that the trigger bar had been pushed back. I spun it back around so that it would make contact and in the process a wire let go  poor solder joint.     I have two ultrasonic base units I would like to send to someone and get them repaired.  Is there anyone around that  troubleshoots/ repairs them?
hi, I found a Old L&R master watch cleaning machine , marked L&R master
any idea on how old the machine is ?
will post a couple of pictures is asked ?
also is the electric cord have a two or three prong plug ?/
please post, many thanks, rocky
hello all , can someone please assist me I require a wiring diagram
for L&R watch master [ serial range 79,xxx ] someone replaced the
electric cord and wired it direct.
 I have read these a wiring diagram under the plate on the bottom
of the machine , mine is missing the plate,
can some please post a picture, many thanks, rocky
If you can't get an exact size, just get something slightly larger and file/sandpaper it down to the correct dimensions. If the pigtail wire is too long or has a different terminal, cut off the old terminal and spot weld or solder it to the new brush.
I do that all the time for the motors I repair.
  • 2 months later...
Old post new user.
Here is a 3d print of a "scaled" mason jar lid. Scaling doesn't always work for 3d print files unless they are parametric designs. It worked well  in this case.
374583869_download(3).png.0fc76e96ded43d1744ed14ce856b607a.png1924839864_download(2).png.7b9af44ceb174ac2fc93beaca13c0e0f.png366257157_download(1).png.e5b072b084ca63a6d2e3bfdf6bbe5e6b.png
The L&R cleaner and rinse I am using came in plastic jugs so I am expecting PLA printing material to holdup just fine. ABS could also be printed.
I started with the stl file below and expanded it so the absolute outside dimension was 4 inches between the tips of opposite points.
Enjoy,
Matt
wide_mouth_jar_lid.stl
Edited by Nibbler
I've got a couple of machines, a Mastermatic and a vari-matic.  I have to restore both, but started with the Mastermatic.  Got it torn down, but the basket motor is beyond my capabilities to restore.  Does anyone know of a shop in the US (I'd be glad to ship) that could handle the motor repair/restoration?
Thanks!
On 12/1/2020 at 4:34 PM, Nibbler said:
Old post new user.
Enjoy,
Matt
Thanks for sharing!
The OD of the threads on my L&R jars is about 3.75".  Yours is 4"? The Mason jar threads match the L&R threads once you scaled the model?
Thanks again!
Woody
Edited by B42Woody
More info added.
On 1/24/2021 at 2:52 PM, Nibbler said:
So the 4 inches is an outside dimension between the points of the lid.
Thanks.  I measured mine with a caliper.  They're 95mm or 3.74" OD (between the thread points of the jar).
When you scaled up the Mason jar model, do the threads (pitch, height, etc) match your jars?  In other words, do the lids you printed correctly thread/screw onto your jars?
Thanks again!
I took Nibbler's lead and downloaded a Mason jar model from Thingiverse. If you have Solidworks, the Thingiverse download includes a Solidworks part file (and STEP, STL, OBJ). Having a native SW part, I scaled it to match my jars and added the lettering for a bit of pizzazz.  Finally, I generated a 4.5MB STL file and had it printed at my local makerspace.  The print cost was $10 (USD).
It threads on nicely and tightens up. I put some water in the jar to see if the lid would hold liquid.  It doesn't.  So, I'm going to modify the lid model to receive a silicone O-ring or (hopefully) a standard Mason jar gasket.
On 8/9/2017 at 10:10 PM, measuretwice said:
thanks for the input.  The jars and lids are original,each with L&R molded in.  The jars are also molded with threads, however the lids are not threaded - they just sit there.  I've read L&R had thread-on lids but they seem somewhat rare.  It seems like it would have been a good thing the have, I mean who wouldn't want to seal it up when not in use?  (perhaps the L&R wash salesman?)  This model btw is the mastermatic.
I looked around the web for a screw on that might fit, no luck.  Cling wrap might work, but I know it would make me mental having t futz about with it.  I I'm going to try the heavy steel lid, and I have some neoprene rubber that would make a good gaskets.  If successful photo's to follow.
https://i.imgur.com/ISt2Uxq.jpg
https://i.imgur.com/XI0F07q.jpg
I see this is an ancient thread...deleting my comment
Edited by LittleWatchShop
stale thread response
TPU also might be a candidate.  I have printed some lids with it (not for this application).  You need a printhead that can handle the flexible filament.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
