eta2801 broken screw....Screwed up need help!
Hi. I doubt you would find an Omega reference number. You will have to measure the holes and pivots, and then order the jewels from a supplier such as Cousins (if you are in the UK). But you will need a jewelling tool to fit them. The other option is to buy a scrap movement and swap the bridges. It's unusual for jewels to be missing like that. It could be that someone has been using the movement for parts and swapping them with poorer quality. Does the rest of the movement look OK?
Thanks Andy the 301 battery had leaked slightly which I cleaned out carefully. I used a 301 battery, but it never worked how do you get the back off if I need to as there is nothing to prise off or turn. See attached photo with battery compartment open.
There's a first time for everything, broken pivot on a barrel arbor, granted it looks quite small and feeble, in a plate jewel as well EB 8021N . Been running like that for a while looking at the wear on the plate. Typical all cleaned and ready for assembly, new balance staff fitted trued and poise checked. Check all the watch parts people before you start cleaning and find the irreparable repair first 🤨. Looks like me and the lathe will be getting reacquainted tonight 🤷♂️ -
By eccentric59 · Posted
It could be that the cap jewels are upside down. That could easily put enough pressure on the balance pivot to stop it.
