Seitz jeweling set
Ok, since today was my introduction to "jewel" issues, I decided to open up the two boxes my Dad left to me.  Identical Seitz jeweling sets.  I think between the two, I have a complete set.  What I need help with is the numbering system (measurement system) so that I can organize all of the components into the right slots.
I found a link to a Seitz brochure/manual on this forum.  It is helpful, but does not answer the measurement question.  I have figured out the reamers because they are stamped.
I think those are measured in hundreds of a mm (Metric millimeters).
As an example I can show the 295, I use a micrometer to measure these exactly.
Here we can se the reading 2.5 + 0.45 = 2.95, in hundreds this make 2.95/ 0.01 = 295.
The types you find in the manual so now you can go on sorting them out.
Edited by HSL
clearer picture
7 hours ago, jdm said:
Shockingly even some American watch factories did, already in 1868
https://www.google.it/books/edition/Research_Report_Number_1_71/AvMcAQAAMAAJ?gbpv=1&pg=PA59
always one of the confusing things in watch repair is isn't just inches or metric there's also some other measurements. Did notice the reference that Elgin is still using inches?
the other place where this really comes up is mainsprings I snipped out some things you can see the Elgin mainspring part numbers the second part of the number is the thickness of the spring in inches. Just because there isn't enough confusion already with mainsprings in metric, Dennison and inches for length Elgin has to have inches for thickness.
There are few versions of this tool.  From what I've gathered, the oldest ones use Ø3mm pushers, which are hard to find.  Current tools and the pushers that are still made are 4mm.
On the newest ones that cap on the head of the stake is threaded on and can be removed.  A smaller cap is placed on the stake and a solid top piece is threaded into internal threads on the micrometer adjusting barrel.  The handle is removed.  This allows the stake to be pushed down by turning the micrometer barrel.  On the tools without this feature the stake and its cap is a single piece and there are no internal threads on the micrometer.
My set is a little different than pictured.  The "reducing ring" on the right end of the 3rd row is missing and there is no space for it.  I don't know what it's for.
I discovered that the two tools I have ARE different.  The base that holds the stump are two different size holes.  I measured one to be 4mm and the other is smaller--guessing 3mm.
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
