Total Newbie confident but no skills
Hi All
I have been watching Watch repairs on Youtube for some time and now feel its time to have a go.
I have a 1976 Marlin Timex with a M27 Movement, this is an old Family watch. It has a cracked crystal and has no life coming from the main spring. i have would it up and released the tension with the click but nothing.
I was hoping to replace the crystal and try cleaning the movement ( with the little you can easily remove, taken off) and then if no joy with he movement replace it with another.
 Also I bought a 1940s Wyler very cheap which has a cracked Crystal and a broken Crown stem. I am keen to strip this down and clean then try to rebuild it.
My main question at the moment is where is the best sites for replacement parts?
All help welcome
Thanks
Richard
Welcome to watch repair and the forum.
Timexes aren't the best watches to start learning watch repair on. They are highly unconventional and spare parts are hard to find. Many members here would advise you to start with pocket watches and China movements.
After you become comfortable with conventional watches, then maybe you can try repairing quirky Timexes.
Hello and welcome to the forum As Hector said the timexe's are not the easiest to start on but on the plus side you only need to remove the balance to clean them. I have attached two documents you might like to read before embarking on your venture. Also added is a tool list which may be of some use for you   cheers.
27 (1).pdf 1961_Service_Manual (1).pdf 1831920544_ToolsfortheHobbyist.pdf
    • While you might have seen it as a humorous/Dramatic remark was done very deliberately so I could get an answer. Let me quote myself? The simplistic of this entire discussion is the group would like the last forever.   If you go to the top of the discussion group you'll find something to click on that says staff. Then you click on Mark's name and you find out interesting things? For instance he was last here on Saturday so yes he is here. If there is a crisis or a problem he is going to be here. You will also find a list of his activity although that's only the public activity. There's a lot of work that goes into running message boards and he probably does a lot of stuff in the background that we don't see to keep it going. Unfortunately message boards do not run themselves. Then regarding this did you notice you can message Mark and ask him. Then if somebody, we could elect somebody from this discussion such as @Neverenoughwatches To reach out I would really keep the message super simple like? You could refer him to this discussion but I would really keep it simple Like for instance the group enjoys his message board and what could we do to keep it going Forever? Then regarding all of the other suggestions comments helpful remarks or ideas? When was the last time any of you bothered to read the message board rules? This is covered which is one of the reasons I did the dramatic things I did to provoke a response of the basics as opposed to starting to suggest or seemingly suggesting all sorts of ideas which are covered by one of the rules found in the section on rules. In other words I'm going to quote something from the rules of the message board.
    • For me any input from Mark would be great. If he's keeping a close eye i would imagine he has read about our concerns here. But specifically i would like to know if he is ok with us collecting each others contact information for those of us that wish to provide them.
    • Thank you!   Yes I did. I did not notice a difference. Although 9415 is advertised as a thixotropic grease (and I did had high hopes for it), the only advantage at this point I see is that its “easier” to apply than an oil (if one does not use epilame). But this is subjective, I guess. What I did notice though, if you apply a bit too much grease, that definitely slows down the movement. Oil in this case is a bit more forgiving, as its super thin, and it would usually just spread out.  Again, imho.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
