Happy new year!
54 minutes ago, oldhippy said:
I'm looking forward to being out of the the bloody E U and not having other countries telling my country what we can and can't do.
THAT would be a wonderful 2021 present for Denmark too, getting out of the ESSR ! Congrats with your new freedom !
Edited by Endeavor
HAPPY NEW YEAR to all members  And well said Oldhippy   I second that motion,  being run by Beaurocrats and self indulgent politicians with no Idea of reality is no fun. Onwards and Up wards.  But not forgetting our friends in the European countries who have no choice,  we are still your FRIENDS.
It is such a momentous turning point in our History to be once again a independent nation, I usually watch the fireworks display on telly but had to turn it off after two minutes it should have been a celebration of red white and blue but sadly chose to feature too much blue and gold for my liking, democracy brought about change that some politicians and media outlets still have great difficulty accepting.
Edited by wls1971
4 hours ago, oldhippy said:
I wish everyone a Happy New Year on here. We don't wan't anything like last year. I'm looking forward to being out of the the bloody E U and not having other countries telling my country what we can and can't do.
Good point! But I am sure the same statement is true for all 53 Commonwealth "independent" countries, right? They also do not need to be guided by UK .
You see, be careful what you say ?
Any member state of the commonwealth can choose to leave but it is also open to join or re-join which some are in the process of doing no country is tied to it.
    • Surely it depends on the clock , I only usually restore torsion clocks and I only use oil on mainspring ( small amount) but on the few so called normal pendulum clocks I have done I have used mainspring grease as there is more reserves of power than there is in a torsion clock so it is not so critical. Dell
    • https://watchguy.co.uk/cgi-bin/files?showfile=Venus/Venus 178.pdf&filename=Venus 178.pdf&dir=Technical Manuals&action=documents   The hour recorder is driven by the barrel and it will only stop if it is held by the hour recorder stop lever 8690. So I would check if this lever (powered by the spring 8691) is really holding the hour recorder in the "chrono off status". I haven't worked on a Venus 178 so far, but on an Omega 861 I chose 9501 grease for the friction spring as it's moving very slow at quite high tension.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
