Lip r 148 movement.
markr
Knowing nothing of quartz watches when my Waltham diver died I got a running donor watch with the correct R 148 movement.  It came running but two weeks later when I went to swap movements the donor stopped.  Yes I did checked and replace batteries.  When I pull on the donor movements crown the balance spins 4 or 5 times then stops. Push in the crown and balance turns once or twice and stops.  What should be my next move?
I may be wrong here but I don't think this is a quartz watch.
52 minutes ago, Nucejoe said:
Isn't this electric?
I think the battery is probably a clue that it's an electric watch.
Do you have any electrical test equipment as this is A electric watch it be nice to have a power supply and some way to measure current and even resistance?
Then we really need a service manual for this one. Some balance wheel electric watches had a hack or a method of stopping the balance wheel. Then when you push the crown in a given to push so it take off and run and that's what you may be seeing right now when you're playing with the stem of the crown. Because otherwise to get a clue we need some electronic test.
Electric watches are fickle and often need a good shake to get them going.
If a good shake gets it running and it then stops again it's time for a service.
A bodge alternative to a service is to spray a degreaser on all the pivots and contacts........and you might get lucky.
Looking at the photo of the balance again I would say the beat arm needs to move clockwise by 15 to 20 degrees comparing it to other Lip r 148's on the web. Or pushing the rate arm anticlockwise to get it in the middle before the bend in the hair spring. This may help.
Edited by Melt
  Its electric, Mark says he knows nothing of quartz watches.
I know nothing of either one, but I can repair em.
Mark;  How freely does the balance wheel oscilate as you shake the watch, nudge the balance wheel to turn it, if at some point it kicks and shows any sign of life, its likely to be out of beat so bring the beat adjustor arm=( stud carrier arm) to the position that makes it kick. The sucker should kick and run.?
Regs
Joe
Just a thought.  Are you sure the battery has 100% full voltage. It looks a bit domed (it should be flat) which is an indication that it is at the end of life and may not be giving enough voltage output.  Did you check voltage with a meter, it should be as near as possible to 1.5v, most new cells are about 1.56v. Below 1.4v and it needs changing.  Even 'new' batteries may have degraded in storage, so ensure it is a fresh new battery not one from old stock.
As you check the battery before why don't you take it out now and check it again?  It sometimes comes up in quartz watches  the shape of the negative contact  doesn't always have the desired effect if it's not shaped correctly. So I look at the pictures the insulator isn't very big it's possible your battery is shorting itself out if the insulator isn't covering everything. Ill be easy to test for you take the battery out and see what its current voltage is if it's down considerably you know you have a problem otherwise it's probably fine.
50 minutes ago, markr said:
The tab on the balance seams to be attracted to the tab on the coil.  A puff of air will swing the balance a few times and then the two tabs act like magnets.
Lip was working with Elgin who had a very interesting idea for basically enhancing the magnetic field.. Lip is using the same technology you're right the tabs are magnets but electromagnets. One end of the coil with its tab is one poll.. The other end of the coil is magnetically coupled only around under the balance wheel up through the balance wheel  to the other tab.. Then  alignment of things is critical  because when the balance wheel is in the right position  it engages the contact which turns on the electromagnet  which attracts the balance wheel tab to the stationary end of the coil. Just before  contact opens in the balance wheel swings past.. So if you start pushing things around just because you're going to have to put them back exactly where there supposed to be or the watches never going to run at all..
Then the contacts and the stuff that can move around shouldn't move around by itself so I would go back and look at  whether the battery is actually supplying power to the watch Or whether it somehow shorted itself out..
Its supposed to, so to set the oscilator in motion, however, as balance turns at certain angle electric current is to get switched off which switches  the magnetic field off, so that oscilator would be free of reaches its max amplitude and turns back to completes a full oscilation, where the current gets switched back on again.
John well covered all there is , the electric circuit doesn't switch off or it does so way out of beat ( correct angular position of balance).
Try demagin the hairspring, if it is sticking it will keep the balance out of beat.
or its a short circuit somewhere.
Good luck.
4 hours ago, markr said:
Do I need to remove hairspring to demag or can I do the whole movement?
You very definitely do not want to demagnetized the entire movement. Typically with electric watches balance wheel type there will be permanent magnets. There's usually one to hold the escape wheel or whatever it's called in place and this watch has one of those. Then the other problem would be here inducing up rather strong magnetic field with a watch that has a coil and at its going to generate energy that conceivably could burn the diode out may be. The diode's there to protecting its back EMF from its own the coil and a very strong magnetic field conceivably would be worse in the field its own coil could generate. Then personally I would doubt that the hairspring would get magnetized because it should be a nonmagnetic hairspring.
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
