Watching a cowboy at work.
oldhippy
7 minutes ago, Tudor said:
Nice gloves... probably to cover the scars from the last time he tried that trick?
The gloves are very good there made of a rough suede leather and very thick I have a pair for mainspring removal using a Ollie Baker for fusee spring removal the gloves give plenty of grip on the barrel.
Bl**dy hell PLEASE DO NOT FOLLOW THIS PROCEDURE>> Not only is there a great risk of distorting the spring the loss of an eye is a real possibility. Some of these springs really fly. If you do not have a dedicated spring winder and want to try his method you must have the barrel inside a clear thick plastic bag when undoing and still wear eye protection and gloves etc.
6805091_Essentialifyouusethismethodtoremoveaspringinthismanner..thumb.jpg.1c5c2db682d2844cf1c63205bee73c04.jpg
I can see nothing wrong with this method providing you adopt suitable safety equipment such as that below. Do not expect the spring to be any good though after and I would recommend obtaining and fitting a new spring. Should you try the method without the shown PPE below  then prior to spring removal  also get a quote to redecorate the room you are in as there is a great possibility that you may splash some red pigment on near wall coverings and furnishings.
3:29  Oooooohhh that went silky smoothly, I bet nobody else saw that coming. ?
I remember doing something similar with an old Hornby clockwork locomotive that no longer worked, when I was a kid (showing my age again).
I undid the four screws holding the thing together and there was a very similar explosion of uncoiling steel with the addition of a few airborne cogs, and a very confused me sitting thinking bloody hell how did they manage to get all that spring in there, and how the heck am I going to get all the bits back in.
Speaking of which, how the heck is he hoping to get it all back in? Superglue and a hammer?
AndyHull grabs the popcorn and starts looking for the follow up video.
Edited by AndyHull
    • The Watchmaker gave me some info on this a couple of years ago, the brands may be connected, I'll see if i can find it Scott.
    • How about using a magnetised screwdriver for picking-up and fitting screw, then run the assembly through a demagnetiser.  I know magnetism is a no no, but this method is less fiddly, and has worked for me on several occasions.
    • Find a plastic tube, cut longer than the K&D, put your tools etc in it and hold both ends.  The plastic shouldn't have any effect.
    • Hi, I’m thinking about upgrading my demagnetizer and wanted to check to see if anyone has experience (good or bad) with the Chinese knockoff of the Elma demagnatizer. At present I use the cheap blue job on watch movements and while a tad clunky it seems to work OK for movements. However it doesn’t really handle tools and other larger pieces (like my anvils which are very magnetized) particularly well. i also have a US made K&D demag unit but have put it aside permanently re: it is so strong I can’t hold the tools, anvil whatever stable enough while passing the piece through the donut hole and ultimately the piece ends up more magnetized then when I started. Feedback would be most welcome since I can’t justify the $299 for a Elma unit but can spring $49 for a Chinese knock off.   thanks jay
    • Hi there, welcome
