omega 283
gary17
Usually to get the correct answer it would help to post a photograph. Otherwise you get the correct answer above but is it the correct answer for your watch? I was looking at the parts list and it looks like the spring that does not go on top.
It's the amusing problem with watch repair lots and lots of variations. All these companies had clever ideas for doing things sometimes I think to get around patents other times perhaps to have their own patents or just because They like torturing the watchmaker.
The problem with your watch is it's cold and trying to find a really old tech sheet is a problem. I think with this one it goes underneath because If its on top I don't know if there's enough clearance between the pivot and the little bridge that holds it in place.
The springs goes underneath the pinion and the bridge on top, there is to be a .02mm clearance between the pionion and jewel thats in the upper bridge. Oil top and bottom interfaces of the pinion with the spring and the jewel. The spring is to hold the pinion high enough to engage leaves with the other wheel.
Both the spring and minute arbour look like they have had it, I am not sure if oiling would be enough, I would polish both.
Good luck.
Good luck.
Some say the clearance is not neccessary and the pinion should barely rub on both side, but in this case no clearance might eat amplitude or even stop the movement couple of months down the line.
This is how your spring should look.
Your looks a bit bent out of shape, but as long as it pushes up in the correct place on the underside of the sweep second pinion, all will be good.
As has already been said,  the brake spring (which is made from beryllium copper) pushes from underneath the pinion and needs a small dot of grease on the spring where it makes contact with the underneath of the pinion leaves.
It tends to be obvious which way it pushes the sweep second pinion, either from the top of bottom, when you see the spring in place without the sweep second pinion. The spring will show it is pushing down or pushing up, unless it has been badly mis-shappened like yours.
I could be wrong, but I think it may have been the intention that the fancier beryllium springs were left dry. The material has a unique ability to work against other metals without wear. I’ve not seen it mentioned on Omega tech sheets in terms of lubrication. I used to always oil them but then also needed to bend them to increase the friction, so now I just leave them as-is. Would be interested to know if anyone has an original tech sheet which mentions them.
2 hours ago, Tudor said:
Can I have a copy of the Omega oiling chart(s) you have please?
The problem is this watch is too old we need something newer with equivalent spring to see what the recommendation is. But if you'd like an Omega oiling guide you can find it In the list at the link below.The reason there is a list is it covers all of Omega's working instructions that cousins has which is not all of them unfortunately. But you might find something else of interest in the list also. You're looking for number 40 by the way.
Then the problem with omega having of these working instructions or the equivalent for some time that would explain why we find lubrication instructions sometimes lacking in the regular technical guide because they want you to look at the lubrication guide instead.
https://www.cousinsuk.com/document/search?SearchString=Working
That, is an excellent resource, thank you!
I have downloaded all the Working Instructions there, so I have them for future reference, even though I don't foresee working on a ceramic case Speedmaster any time soon...
I have harvested documents from Cousin's in the past, but hadn't come across these. Much appreciated.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
