mystery LED/LCD watch
i know most of us are faithful to mechanical watches but now and then i come across a quartz LED/LCD that intrigues me and have such a one which was bundled in with a package of spare parts /cases etc i came across.not much to go on apart from a number inside 1256-701 and a case no 5956 neither of which reveal anything online!.anybody any idea? thanks B.
Well  its definitely LED and looks like an early one on a ceramic board also non sealed wire bonds.  Board looks to have a massive crack in it unfortunately.
I have tried and failed to get these going in the past. some Trafalgar's that use National Semiconductor modules  you stand a chance as the board is stronger.
The case on yours looks like a very generic 70s
9 hours ago, WatchMaker said:
Compuchron?
Check out picture of movement at the bottom of this page: http://www.crazywatches.pl/compuchron-hughes-aircraft-led-1976
I think you'll find a lot of the early LED modules look like that like same website different company similar look.
http://www.crazywatches.pl/timeband-fairchild-led-1975
then anything with open wires on the integrated circuits and the LEDs are very problematic it's extremely easy to damage the wiring. At one time somebody actually made a kit for re-bonding the wires if they fell off which occasionally they would do and that was a real pain to try to fix. Fortunately they got smart and started encapsulating everything one less problem out-of-the-way. but no matter what you're still caught with a problem the integrated circuit is like a black box. We don't have any way to access the inside and even if we did we have no way to fix it. The basically end up with a lot of early electric watches that don't work and there's no way unfortunately to fix. Which is sad expression a watch repair discussion group where we would like to fix them.
That's rather dismissive of my amazing find John! ;)
Just for clarity where I was coming from was the very clear similarity between @berniethebolt 's picture and the one on the page I mentioned ... even down to the serial number placement and format.
thanks to all who answered.i was just curious but is obviously not salvageable so i will try to utilise the case at some point! B.
Well the abbreviations inside stand for 'North American Foreign Trading Corporation'..... a starting point for more research....
 Something else that they were responsible for in the 1970's, HERE......
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
