I've started trying to replace balance staffs in pocket watches. My first victim is an Elgin 0s model 2.  I've got the correct tools for the job. Disassembly went fine, but after installing the new staff the balance wheel now has a slight twist to it and wobbles. I "tried to fix it" with a pair of parallel pliers but have only made it worse.  It is now also out of balance.
My questions are, What did I do to cause this?  What steps should I take to avoid it again? Lastly how do I fix this one?
Thank you in advance,
Nora
Nora
Hi Nora,
There are actually a couple other threads here of people who went through the same thing, that is wobble after replacing a balance staff. Here is one:
Another thing I can think of is maybe the wheel was damaged process of replacing the balance staff and needs to be poised. Here is an article talking about checking poise and poising a balance wheel:
https://www.great-british-watch.co.uk/how-to-poise-a-balance-wheel/
Hope this is helpful!
43 minutes ago, HectorLooi said:
OMG! As a newbie you replaced a balance staff? :startle:
How did you accomplish that?
I watched Mark's video on it twice and thought I can do that, so I did. :unsure:
What method did you use to remove the old balance staff? Did you use a Platax tool, K&D balance staff remover or did you cut the rivet off on the lathe?
In my book,  The 80% you have already achieved is a prerequisit for the remaining 20%.:Bravo: .
1 hour ago, spectre6000 said:
Jump in the deep end! That's how winners roll! That's also how you break things, but you learn more and more quickly that way. Kudos.
The deep end is an illusion. You can float in 3 feet of water and not touch the bottom doing so. You can float in 300 feet of water and never touch the bottom. Both feel the same way, so it then comes down to how far from shore do you feel comfortable being.
Cheers!
Hi well done so far Now you need to learn trueing the balance in the calipers and poising the balance.  Firstly you need a pair of truing calipers or a truing jig so as to get the rim running flat then poise the balance in the jaws to check if there are heavy point, either of these being out of true will affect the timing rate . Pictures of the tools  below.:thumbsu:
I have an "Automatic Balance Staff Remover" made by the M-B Tool Manufacturing Co. Sorry about the picture quality. I only have my what's only phone.
Cheers!
https://xkcd.com/2155/
watchweasol
I won this on auction a couple of days ago. It is on it's way. I suspect that the set screws are missing judging by the picture on the box, but I can sort that out once it gets here. It otherwise looks complete to me. I'd eventually also like to get the other model you show but is not in the foreseeable future. An ultrasonic cleaner will come first.
Hi  you are nearly therewith the tools. the little wrench is for tweaking the balance arms,  Unusual for the staff removal tools to distort the balance they are supposed to keep the arms flat to the stake during removal of the rivit.
Good for you, that attitude will take you a long way! Personally, I've been doing this for a few years now but so far I've only dared to secretly think about balance staffs a little. ;)
I offer this to you as encouragement. Stop just secretly thinking about it.  Buy a watch with the part you want to work on already broken and give it a try. you will get one of two results. It will still be broken in the same way as you started with or it will work out. I call it the rule of 50. 50% it will, 50% it won't. It's like the old adage "you won't  know till you try. Worst case scenario, you try it and don't like it. In that case resell the movement and the tools for what you have into them, and move on.
  • Like 5
Thank you @Nora! My post was meant as a friendly encouragement as well but I don't think it came through all that well. I'm deeply impressed that you would go for this rather tricky operation so soon. Watch repairing has many, many challenges, and I guess it takes a while before you've taken on most of them. Next on my list of challenges will be dynamic posing and resetting/adjusting pallet stones. Before this I was happy to succeed with replacing jewel bearings, adjusting end shake, and adjusting a hairspring. "They" say there's nothing magical about mechanical watches and Precision Mechanics, but I somehow hope I'll never get to realize it :lol:
Good luck! :thumbsu:
1 hour ago, rodabod said:
Did you bend the arms or the rim? Or both.
I'm not sure. I took the staff back out and set it on the staking table. This is obviously  not to scale but an approximation of what I see. The actual gap I'm guessing to be about .002" /  .051 mm. It was a lot worse with the staff in.001.thumb.jpg.d2d1e737ce7b8b17a137401a13938eb8.jpg
I start with the arms and some finishing touch on the rim.
In case the wheel is out of round, a truing caliper is neccessary.
So. Would you like me to make a video on how to straighten a Warped or Fouled balance using the proper calipers; etc?
I did that for the first time a short time ago, at Master's workshop. Balance wheel alone, he handed me some sort of calipers with bronze (?) jaws, told me to hold the balance tight in one hand, grab the spoke that shows as high on the huit-ciffre, pull down a bit. So I did and after checking it was deemed "not so bad"  :biggrin:
Edited by jdm
I have done this number of times. First, years ago, it was a balance that I warped by tapping too hard when installing a staff. Then it was the occasional balance in pocket watches I was repairing that were “out of round” and also not flat. I got pretty good at Rounding and flattening balances. As well, I have had to flatten the arms in a staking set prior to bending the balance back to true. I have also adjusted the balance of the balance with the screws and washers. I have also undercut screws to adjust the weight. So I thought a video on this topic with some discussion on how not to screw it up in the first place, followed by how to fix it.730460198eccf576961e91123887c6d5.jpg
And I have fixed a few.
That would be very helpful.
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
