Watch Hand Metal?
dpn
So, I'm looking for an inexpensive supply of steel hands to practice heat bluing with.
Looking at esslinger.com, there are lots of "silver" hands available for a reasonable price. E.g.: 114 Piece White Multi-Style Watch Hands, White Dauphine Style Hour and Minute Hands, etc.
There are also, of course, a myriad of cheap silver Chinese hands available on eBay.
Does anyone know what metal inexpensive "silver" hands are typically made out of? I'm very, very new to this, and honestly don't know whether hands are typically steel, anodized aluminum, or whatever ...
Thanks in advance for any tips and advice!
Steel is what you want. Preferably stainless. Get a magnet- good quality 304, 306, 316 stainless alloy will be non magnetic. Try ofrei and kas-ker. otherwise vintage NOS is always good but like we talked about-can get spendy.
Otherwise some can be cheap tin or aluminium. Even plastic.
Stainless steel won't blue; I don't know of any watch hands being made of it either.
If the supplier doesn't state or know the material check them with a magnet. Hands can be almost any material from gold to plastic but brass and steel are the most common.
Yeah, they're out there. All modern day stuff. Micro brands.   Depending what grade and carbon content they contain  they will turn color tho. Manufcrs. don't list the grades tho lol. Just keep my trusty magnet handy. melted a plastic set once..
I've got my propane torch, my IR thermometer, my brass scarf, my brass heating box, and my polishing stuff all either here or on the way.
I honestly didn't think that finding steel hands was going to be the hard part! *grin*
I can practice a lot with screws and old blued hands, but if I want to actually make usable hands I'm going to need to figure out a supplier.
Interestingly, Esslinger has been super quick to reply to my parts inquiries. My inquiry about what makes up their "silver" hands has been met with silence, so I agree they're likely to be some kind of mystery anodized or coated base metal.
This has been, and will continue to be, a fascinating exercise. I'm going to be cross-posting on the NAWCC forums, since there's a lot of good heat-bluing info there. Maybe someone will have a good supplier they'll be willing to share.
The better the quality of the steel and with practice the better the bluing will be, you should have an even blue colour all the same. I always quenched clock hands and screws in oil, it would give a shine look and not a dull finish.
Where did you find the swarf and heat tray?
Do you every get the black tar-like crud on them when you do this? Ever had and luck with just air cool down?
If its screws after they have be cleaned and polished, I would put them in an old watch cleaning machine to make sure all dirt got completely removed, crud can be caused by bluing something that still has dirt or grease on it. Hands would be washed in soft soap and warm water and dried in a lint free cloth before bluing.
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
